Conquest 42 Bar feeder wiring
Results 1 to 8 of 8
Thread: Conquest 42 Bar feeder wiring
    Mar 2013
    Default Conquest 42 Bar feeder wiring
    I've been given the job of interfacing an SMW Spacesaver 2000 bar feeder to a Conquest 42 lathe. We currently have two of these bar feeders that I interfaced, so I'm familiar with the spacesaver.
    I have no information on the Hardinge side of the interface.
    Any info would be greatly appreciated
    Default Re: Conquest 42 Bar feeder wiring
    Any luck with this? I am trying to get a T42 running that previously had a bar feeder attached to it but can't seem to locate the correct terminal/wiring that may need to be changed. I think I need to jump the estop wire circuits together but can't seem to find them.
    Mar 2013
    Haven't found anything yet. Hardinge was going to send me a pinout but they apparently got my email address wrong, trying to make contact with them again.
    I have an wiring diagram that came with the old barfeeder but the lathe side pinout is incomplete.
    Jul 2014
    Hi Guys,
    What year are your machines? I should have the drawings on file and can send them on.
    Mar 2013
    The books I have for my Conquest 42 are all dated '88, can't find a date on the machine.
    Mar 2013
    So I've physically traced the wires from the interface and identified them all. Now I have questions about a couple of them.
    Here's what I've got;
    Pins
    1) 24vdc
    2) no pin
    3) EOB from bar feeder
    4) no pin
    5) Ground
    6) Bar feeder ready signal
    7) E-stop of velocity unit ( I'm assuming this is lathe estop )
    8) 'Air Bar Pressure' ( is this the push signal? )
    9) E-stop of velocity unit ( paired with pin 7 )
    I'm wondering are pins 7 and 9 a NO/NC lathe estop circuit?
    and is pin 8 the 'Push' signal?
  7. #7
    Mar 2013
    I can now cycle the bf from the collet open signal.
    I now need a place to put the bar feeder M finish signal.
  8. #8
    Mar 2013
    So I ended up faking the bar feeder by simulating necessary signals with some relays.
