- Need help regarding HARDINGE SUPERPRECISION Lathe CHNCI
I need help from an experienced user of Hardinge Superprecision Lathe CHNCI to identify the parts required to repair my lathe with part number as well as the source of supply, the HARDINGE INC., USA is not cooperating due to their company policy that we should go to the distributor, the distributor of our region is in INDIA he do not do any service for Pakistan and I am in great fix, I do not have part manual so I can not get part numbers. So if some body have part manual or by experience can guide me wit part numbers and source of part supply other than HARDINGE INC., USA, I will be very obliged, I am giving below the part description: The parts are of TURRET INDEX MECHANISM:
1. 4 way valve R481 electronic made by Clippard instrument laboratories
2.Base for the above valve of Aluminium matel.
3.Rubber gasket for above valve and base. please refer maintenance manual page 38 figure 78
4. One check valve ( written on it Mead Chicago HT-100P ) please refer maintenance manual page 36 figure 69 .
- You may not post replies
- You may not edit your posts
Forum Rules
