Shipping Conquest T42 - Necessary to lock the X, Z, and sub-spindle axes?
Results 1 to 8 of 8
Thread: Shipping Conquest T42 - Necessary to lock the X, Z, and sub-spindle axes?
    Sep 2010
    Default Shipping Conquest T42 - Necessary to lock the X, Z, and sub-spindle axes?
    Gentlemen,
    Getting ready to ship a 1997 Conquest T42 and the seller is asking how to lock the axes (in this case, X, Z, and Y (subspindle.)
    Do any of you recall removing a pin, or a block of wood, or any kind of fixing mechanism that kept the X and Z axes in place during shipping?
    Torin...
    Nov 2008
    Default Re: Shipping Conquest T42 - Necessary to lock the X, Z, and sub-spindle axes?
    When the machine was new, it came shipped with RED brackets that connected the axis to the machine base. And I believe there was a RED bracket for the Sub-Spindle casting. Most people lost these brackets. If you have them, you will be able to see where they go by lining them up near the axis motors and the bracket near the Sub Casting.
    One T42 we bought used:
    I just went to Home Depot before the machine shipped and bought some 2x4's, WD-40 and shrink wrap.
    Cut a 2x4 to fit tight between the Sub and the Main Spindle. Came down off the Turret with another 2x4 into the Sub.
    And screwed in all together tight. Soaked the inside of machine with WD. And then shrink wrapped the entire machine top to bottom.
    Made it fine to our shop 350 miles away. Boards were still tight and machine was good to go.
    NOTE: Your 1997 might have absolute encoders. If the bats have gone dead, you will need new bats and also need to do the zeroing procedure.
    I can help you if you need.
    Good luck!
    JT
    Sep 2010
    Quote Originally Posted by JohnnyTurn View Post
    JT
    Hey thanks for responding. I spoke to Hardinge last week and they said the same thing - that new machines are shipped with brackets, but in their absence one should position both the turret and subspindle mid-way through their travels (to get them away from their hard stops) and to use a very dense piece of foam and squish it slightly between the turret and sub-spindle. I also suggsted the seller run some RV-grade (non-toxic glycol-based) antifreeze through the coolant lines. Last time I had a pair of water-cooled lasers shipped from California in the month of Jan/Feb, the heat exchangers on both fractured due to freezing en-route. Lesson learned there, obviously.
    Yes, this machine has absolute encoders that went dead during storage at the seller's facility. Their technician re-zeroed the them and used a 6V lantern battery to keep the juice flowing, but I will indeed want to re-calibrate the axes once I get her here. I have all the manuals now, but I've read somewhere here (or, ahem, the other site whose initials start with P and end with M), that the zeroing procedure isn't written properly and therefore would love to hear your advice on the topic.
    Well, I can't wait. Just spoke to the seller today and she's all palletized and waiting on the transport company who is a day late getting back from Mexico. Within 8 ~ 10 days, I'll be Christmas all over again. Man, am I stoked.
    Torin...
    Nov 2008
    The Hardinge books are very good. Yes there may be a couple of things that can be off. But for the most part they were the best written technical books for their time. Mostly because American men and women wrote the instructions. It was not Jing-lish!
    The re-zeroing is not tough. I also can tell you how to make up your own battery packs and use either AA lithium or alkaline batteries off the shelf. When you have 10 of these machines you get sick of buying the special Panasonic lithium from Hardinge or any other source, trust ,me!
    To me, the T42 was one of Hardinge's best, if not the best design they ever had. It really is a tank. And what the new regime at Hardinge does not understand: If you make a Rolex watch, expect people who bought it 20 years ago to still want service. Cause guess what? It still runs!
    Just let your rigger know about the full Harcrete Base. Ask if he has moved Conquest 42/T42 before. There is ZERO cast iron in the base. And other than the fork tunnels, there are almost no jacking points. Trust me, I have heard the cursing and grumbling from riggers laying on their sides. And yes, that little machine weighs in at almost 10K. Five tons. Warn them over and over.
    Good Luck.
    Sep 2010
    Well that's good news - I've nearly read them from start to finish and if they're anything like the CHNC manuals, I'll be good. As for the battery packs, how many other batteries are on this machine that I should worry about? Using a 6V lantern, or wiring up a quad-D-cell battery pack will cover the absolute encoders, but the next part that worries me is the control's memory. Need to come up with a solution for that one too, and only using standardized cells. What battery packs other than for the encoders have you devised? Hardinge gave me every datafile uploaded to that machine when it was built. I love those guys, but their younger staff had better keep up with their product or they could lose the following their older employees fostered over so many years due to (in my opinion) excellent products and service.
    My rigger knew about the lack of jacking points before I did and suggested a shipping pallet (for an additional $1100 - painful, but worth it). He was going to use the feet on the lathe and somehow make those go through the pallet until I looked at the drawings and saw three recesses in the base with drilled/tapped mounting holes for the original shipping brackets. Another call to Hardinge confirmed we could use those, so now after fashioning brackets, he has bolted the T42 to three main beams running the length of the pallet. The pallet will in turn bolt to the flatbed. It will be a helluva lot easier to unpack this way, I'll tell ya.
    There are so many questions I could ask about the T42 - like, what effect does temperature have on the lathe during warmup? I run my CHNC out of a partially heated garage here in Canada, I keep it at 10 degrees C and it warms to 25 degrees C after a long day of constant machining. During that time, I might have to adjust the X axis by a few tenths just to keep certain cuts aligned to within 0.00005. If I can look at my part through a 20x loupe against the light and see no variation in height of the two surfaces, then I've dialed it in properly. Between 10 and 25 degrees, I might have to add .0001 to the diameter every few hours to keep it that way. I always thought the "T" in T42 stood for temperature-compensated, but Hardinge told me that's not true. It stands for "turning", which is quite anticlimactic after all this time.
    Also, according to the drawings of the English and Metric turrets, the slots in the front vary in width - the English is 1.5", whereas the Metric is 40mm. I suppose the Metric tools cannot be used in an English turret (unless they are trimmed) because of that gap difference... That really bugs me. So many tools are available only in metric now. Stupid 20mm tools...
    I have other questions, but I could write all day long and still not be done asking.
    Torin...
    Nov 2008
    There is a battery for the LA axis (SUB) in the Aux. cabinet to the left of the machine.
    Then two more batteries in the main electrical cabinet. One is for X,Z and turret.
    One is for machine memory.
    The memory battery has much less draw placed upon it. And will last longer than the axis Batts.
    The Axis Batts. will last just over a year and die.
    So make a large note and attach it to the outside of the machine indicating on what date the Batts. were changed and when you must change them again.
    I like to do it one month before the date listed. For safety
    It is also good practice to change the memory battery while you change the Axis Batts.
    You will see with a multi-tester that the memory Batt. will only have dropped about a volt to 1.5 volts from new.
    But, better to just change it while you are in there, than risk forgetting next time around.
    One thing to remember: Leave power on in machine when changing batteries. And don't do it during a storm or when there could be a chance of a power outage.
    To make your own battery packs:
    The Fanuc drives have a small, two pin connector for the battery leads to attach to.
    I had been buying many batteries through the years and had kept all the dead ones in a drawer. (lucky)
    You will need these (special) two pin female connectors to make your own battery packs.
    You could, power up the machine, remove one Batt. and cut the leads from it, then solder that lead to your new battery pack.
    What I do for my battery packs:
    Purchase a (4) AA battery case from an electronics supply, Etc.
    4x1.5=6v
    Also purchase a Velcro strip kit that will have adhesive backed Velcro.
    1/16" Shrink tube
    1. Place shrink tube on wire, push back.
    2. Solder the Fanuc/Panasonic lead to the new battery pack. (make sure to keep polarity correct)
    3. Shrink tube over soldered connection with lighter or heat gun.
    4. Place (4) off the shelf (I Like Energizer) AA Alkaline or Lithium batteries in to the case.
    5. Place cover on case and screw together.
    6. Check and double check polarity.
    7. Clean mounting spot inside cabinet. I used the spot just to the right of the drives. On the sheet metal.
    8. Stick the Velcro to the clean spot.
    9. Apply Velcro to the back of battery case.
    10. Stick the case to the Velcro in the machine.
    11. Attach connector to drive.
    DONE.
    One note on Alkaline Vs. Lithium.
    The lithium, at the end of it's life, will fail abruptly. Like falling off a cliff.
    The alkaline, will slowly discharge and eventually fall to a voltage which will alarm out the machine at start up.
    They both work fine. I started with the Lithium. But now I use Alkaline. Cost savings is always a plus!
    JT
  7. #7
    Nov 2008
    There are so many questions I could ask about the T42 - like, what effect does temperature have on the lathe during warmup? I run my CHNC out of a partially heated garage here in Canada,.............
    The T42 is very accurate. Is yours a T42SP? If so, it will be slightly more accurate. And will have a few features that the standard "Precision Machine" will not have. Like Thermal comp. (done through control) Tool life management. Etc. In the good ole' days at Hardinge. They tried to make all machines to the SP Spec. But sometimes tolerances could stack and the machine could only hold within a couple of tenths. If the spindle and the machine came together pretty much perfect, and could hold within a tenth. Well, they slapped a dark gray paintjob on her and a brass door handle and called her a Super-Precision. Plus $20K more or so. I have an SP. I would say all things being equal. After so many years of running the machine the SP thing does not matter. It might have when the machine was brand new. And if you used it in a lab-like environment. And not running production. Then yes, the SP would be more stable and hold ultra-tight tolerances.
    As to your question about CHNC Vs.T42:
    It is very hard to beat the consistency of a tight running CHNC. And remember the T42 is a slant bed lathe.
    However, once up to working Temp. You will be able to hold tolerances similar to a New to newish CHNC.
    One thing I noticed is that knurling is much more consistent on a T42. On one cast iron Slant, we were getting miss tracks on our knurls frequently. The part was .875" 4140 Aircraft tubing. Sticking out 7" from the collet. Ran that same job in the T42. Miss tracking all but disappeared. Maybe 1-2 miss tracks in 1,000 Pcs. The Harcrete does make a difference. And of course, that Hardinge spindle is hard to beat. If not unbeatable.
  8. #8
    Sep 2010
    "It is very hard to beat the consistency of a tight running CHNC. And remember the T42 is a slant bed lathe.
    However, once up to working Temp. You will be able to hold tolerances similar to a New to newish CHNC."
    The repeatability on my CHNC was incredible. I could G0 away, and G0 back to the same position over and over, and the needle on the tenths indicator never swayed from exactly over the line it started on. It blew the buyer away and he bought it on the spot.
    What does, "And remember, the T42 is a slant-bed lathe." Should I infer from this that a slant-bed is somehow inferior?
    The temperature varies considerably in my shop, and while the CHNC needed a tweak every twenty or thirty parts until the temperature stabilized, it would repeat well enough I didn't need to check each part. I could easily predict how it would behave and it became second nature.
    I'll be disappointed if the T42 doesn't hold at least the same tolerance as my CHNC.
    Torin...
