- Need Help!- Hardinge talent 8/52 FANUC
I've got a Hardinge Talent 8/52 with a FANUC oi-TC control I've programmed it to bar pull parts with an M99 to repeat the program. Does anyone know how I can program this thing to stop after a set number of parts /M99 counts? Please post and example of the code! Thanks!!!
Do you have the run time / parts count option turned on your machine?
Re: Hardinge talent 8/52 FANUC
You can write to a macro variable like #500=#500+1 then after that write IF [#500 GT 100] GOTO 70 Then right after your M99 have M30
#500=#500+1
your program here
M99
N70 M30
- You may not post replies
- You may not edit your posts
Forum Rules
