- HARDINGE CHNC 1 / PARTING OUT
WE RETROFIT OUR LATHE AND ALL ELECTRICAL PARTS ARE FOR SALE.
HARDINGE CHNC I SN 2654 YEAR 1986
MACHINE WAS IN GOOD CONDITION, EXCEPT MONITOR AND X DRIVE AMPLIFIER
MAIN BREAKOUT BOARD
MAIN 24 V POWER SUPPLY
X MOTOR ( MOTOR ONLY)
X MOTOR (COMMUTATOR BAD , FOR PARTS)
Z MOTOR ( MOTOR ONLY)
MOTORS DRIVE AMPLIFIERS, ( X MIGHT BE GONE- NOT SURE- BUT ALL REST IS GOOD) COMPLETE CAGE SEE PICTURE
FANUC SPINDLE DRIVE 3PH, 5.5 KW
AC SPINDLE MOTOR, 3PH, 5.5 KW
SIEMENS 810T GA1 CONTROLLER GOOD
(PARAMETERS ARE STILL THERE) GOOD CONDITION EXCEPT MONITOR WHICH WAS VERY DIM BUT STILL WORKED... BEING ABLE TO JOG SPINDLE, Z AXIS AND INDEX THE TURRET.
SIEMENS CONTROLLER FOR PARTS
TRANSFORMER 13 KVA 575V TO 240/360/480V
TRANSFORMER 6KVA 575V TO 120V
AND MANY OTHER PARTS
IF YOU HAVE A HARDINGE CHNC YOU MAY NEED PARTS I HAVE.
Re: HARDINGE CHNC 1 / PARTING OUT
HI somebody know where I can to fin gray CNC spare parts
I am looking for spare parts for gray cnc machine VFR M-1015, SN 10205.
the gray part number is 121601
descrption pump motor and valves
manufacturer and number DOUBLE A¨PER DRAWING 40-03658-02
Hello "GRUPOMI " welcome ....
my email is ed.murch@mamcomolding.com
looking for spare parts !
servo motor 1 hu5040-0af02-z
maybe send me a list . mine is a fanuc gn10tf control to match up part #s
Thanks Ed
Hi Ed,
Most of the parts are still available (mechanical and electronics).
We removed everything with a value and we scrap the carcass.
When I got some time I will post a list here and on Ebay.
Hardinge CHNC 1 X Axis Servo Motor | eBay
- You may not post replies
- You may not edit your posts
Forum Rules
