Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
  #13
Old 05-08-2008, 11:09 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
Originally Posted by orionstarman View Post
. My problem was that I hit him with a $2000 list of things I think we needed and he freeked out. I'm sure I can get what I need it's just going to take time. The things I really need help with are like this:
this works no better than the way we were doing it before. Should I run it at even higher feed and speeds or go back to the old school way. I.
if youve removed the same amount of material as you have at slow speeds before the inserts wear out ,then i would say you are ahead , time is money!
02" chipload/ tooth sounds extreme for aluminum let alone d2 , that takes some serious force to push an insert that heavy , what kind of tooling and equipment are you running , must be huge stuff
your boss needs to understand that it takes money to make money , to request $2000 worth of tools is peanuts , the last company i worked at would push up to $50,000 / month in tooling and holders , and that was only the milling dept
its not too hard to justify buying proper tools for the job , its simple to calculate the difference in time it takes to run a solid carb, drill vs an hss drill etc. etc.
about the big fat raise , i'd say forget about that , it doesn t matter where you work you won t get a raise for saving the company money because more or less thats what we are hired to do
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
  #14   Ban this user!
Old 05-08-2008, 11:55 AM
Mazaholic's Avatar
Mazaholic is on a distinguished road
I have found what works best is to have a lot of info on what you need and costs.
If you just tell them i need more tools,they will just tell you we need more money.
Get a list of exactly what you need,the cost,the time saved,the cost to maintain.the current cost with what you have.It has to show profit.
You have to show the bean counters that you know what your talking about.Otherwise your just a regular Joe trying to buy something new at their expense.
  #15   Ban this user!
Old 11-22-2010, 11:00 PM
JCVineyard is on a distinguished road
When the vendors come in to try and sell you new tools. Ask them if you might demo a tool. It's easy enough on a mazak to tweek the feeds and speeds, for the new tool. Then you might be able to show the boss the time savings, and increased productivity.
[IMG] code is Off
static from hell swarfmacdaddy General Electronics Discussion 8 02-15-2010 01:09 PM
Helix Hell chutch G-Code Programing 13 09-29-2007 10:24 PM
I'm in CNC Hell---Somebody help me Shinosky Benchtop Machines 1 10-28-2006 05:41 PM
Made in the USA..what the hell does that mean anymore? carbidecraters CNCzone Club House 150 10-28-2005 03:01 AM
I'm in Tap and Die Hell samualt DIY-CNC Router Table Machines 24 06-02-2004 11:00 PM
