Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 12-01-2007, 01:03 AM
katebao is on a distinguished road
HSM research
Hi Everybody,
I have done my Master thesis with HSM: " Optimization the Ra (surface finish) due to changing V,S,t,R. But I can not find out any good HSM book for my basic theory. Only get HSM by download the very short researchs on Google.
Pls let me know the difference between HSM and CNC conventional in Ra,V,S,t,R.
Old 12-05-2007, 09:53 PM
crazythunder is on a distinguished road
I have got some great extensive research done from a U.F here is the link:highspeedmachining.mae.ufl.edu/htmlsite/tutorials.html
I hope that helps.
Old 12-06-2007, 01:53 AM
I can download tutorial 2,3 and 5.pdf only, others can not, which study in Chatter/ Dynamics of High Speed Machining. It is different of mine in Optimization the cutting conditions when considering the affect of V,S,t,D (tool) to the surface finish (Ra) by experimental reseach. Thanks.
Old 12-08-2007, 02:58 PM
andy55 is on a distinguished road
katebao, let us know when your thesis is available online!
A couple of papers by Toh et al come to mind where HSM paths are compared, maybe you know about these already?
http://dx.doi.org/10.1016/j.matdes.2004.09.021
http://dx.doi.org/10.1016/j.matdes.2004.07.019
http://dx.doi.org/10.1016/j.precisioneng.2004.01.001
http://dx.doi.org/10.1016/S0261-3069(03)00160-2
AW
Old 12-09-2007, 05:35 AM
Yes,toolpath strategy is also very important to HSM, but it will be researched later,so toolpath is different of my reseach right now.
I forcus on Optimisation for Surface finish Ra when consider the affect of spindle rpm, feedrate, depth of cut, tool diameter only.
In next 3 months, I will do the experimental stage with Mikron machine (model: HSM 600) with different cutting conditions,then I measure the surface-finish correspond to those conditions by the optical Ra measurement device.
Finally I used the theory of total experimentation to get the formular of
Ra = F (feedrate, depth of cut, tool diameters)?. That is what I need to solve now.
Thanks for your helps.
Old 12-09-2007, 07:12 PM
toastydeath is on a distinguished road
Are you familiar with all the research into surface finish LLNL did in diamond turning? They answered all the questions you are attempting to solve now.
Predicting surface finish is a matter of asynchronous error in the sensitive axis combined with tool sharpness. All your proposed measuring conditions change either the asynchronous error of the system or the apparent edge of the tool.
Old 12-17-2007, 10:25 PM
Hi, I've just finish the theory of HSM for surface finish. Now, I forcus on choosing toolpath strategy, tool to do machining a sample and get result. Thanks a lot.
[IMG] code is Off
EPS & Polyethelene Surfboard Research Spearz Mechanical Calculations/Engineering Design 7 06-22-2007 06:58 PM
project research ramus CNC Wood Router Project Log 0 10-25-2006 09:59 PM
have been doing some research (cnc router) planescott DIY-CNC Router Table Machines 14 09-25-2005 11:13 AM
Research question Chunky General CAM Discussion 16 05-28-2005 07:02 PM
Market Research Andy NC General CAM Discussion 2 07-20-2004 05:11 PM
