| Hard and High Speed Machining Discuss Hard and High speed Machining here! |
| hoss64, I have heard of the "HSM Works" software...but thats about it. No help there. I started going though the machine selection process a couple of months ago myself. I have it narrowed down to the Massura's for us...but the Makino has a great rep as well. http://www.methodsmachine.com/Machin...a/default.aspx |
| Hoss, most newer cadcams can do high speed machining. The biggest problem I remember was at 3.3m/min cutting feed the change in direction was brutal on the ballscrews, mazak drilled a hole thru the middle and ran chilled oil thru. When it changes direction it needs a deceleration path, sort of like a loop in fresh air. (the cutter is tony hawk and the ramp is the workpeice, no dead stops) |
| Hi hoss 64 At the last IMTS were Makinos were being used the engineer that was running them peferred to use GibbsCam for there programing software DL 3.3m/m is not veryfast you should see what 60m/m cutting & 300m/m rapid looks like
__________________ Mactec54 |
#10
#11
| It might have been 33 meters/min. I cant remember, it was 8 years ago on a mazak fjv250 with hyperform V5.2. It seemed very unsympathetic to the machine, it was like hitting the ends of the ball screws with wooden mallet at full swing. They were big time players in aerospace and toolmaking saw those concerns as petty. You or I would cringe (or marvel) at seeing $180k usd mazak used like that. The previous guy smashed it hard and bent the linear guides, they need expert users only. (and lots of solid carbide $$$$$$) |
#12
| At first I was like that but after a while and more experience 150 IPM looked like Sloooooooommmmmmooooooootion. We used a lot of carbide, M42, and powdered metal tooling. Materials like Inconel, Monel, SS 300 series and 400 series, Aluminum 6061, 7075, and Tool Steels. I would say 30% was Aircraft, 30% Tool and Die, and the rest divided among simple molds and odds and ends. There was no hiding in this small shop so you learned a lot. It was a great experience.
| What is high speed machining | Klox | Hard and High Speed Machining | 111 | 01-26-2011 01:21 PM |
| Installing High Speed Software... | sco999 | Milltronics | 0 | 05-01-2007 01:51 PM |
| Learning Delcam High Speed Software | hoss64 | General CAM Discussion | 8 | 01-02-2007 12:27 PM |
| What is high speed machining | johnm | Hard and High Speed Machining | 22 | 12-29-2004 05:41 AM |
| Welcome to high speed machining | CNCadmin | Hard and High Speed Machining | 3 | 03-29-2003 10:45 PM |
