| Hard and High Speed Machining Discuss Hard and High speed Machining here! |
I am looking for some information on High Speed Hard Milling 420 Stainless at 45 Rc I would like to know the best type of tooling, how to program for this, stepover depth of cut so on. Any information would be greatly appreciated. Thanks in advance |
| OK Currently I am using a HAAS VF-2 with a high speed control. I would assume that means it has the aceleration/deceleration option. Yes it can handle large programs. I am using Mastercam as the programming software. There is a chance that I might be getting my hands on a newer Makino VMC. I know that this machine would be the best, but I do not know when this could be happening. I am interested in any information that you could provide me with for both machines. Thanks in advance. |
I am also a mastercam user so i know first hand the toolpaths will work. What will you be cutting.from solid? Are you roughing BHT? You want to use z-level roughing method. Side milling you use 5-7% step over. Cutters: It all depends what you want to spend. Obviously the more you spend the better the tools. You want tialn and ALtin coated cutters. Kobelco,Hitachi=the best Osg,robjack=60-70% price & performance Fullerton,roundtool=good for rough & semi finish. If you want to see some sample Videos go to www.hardmilling.com If you need it programmed for you we can set you up with what ever you need. Just tell Dale Steve sent you. Good luck!!! Last edited by hardmill; 04-02-2003 at 10:13 AM. |
| Usually I will be cutting directly from solid. Would I be better of roughing out the cavities BHT? I have been doing a little of it but I think that we will be getting much more buisness shortly. Your link didn't work for me.
__________________ MachineSMM |
Actually if your tooled right you can rough quicker BHT. Then you free up the machine to rough while your tool is out to heat treat. Its all a matter of how you personally want to do it. Inserts to rough are much cheaper than end-millls for hard milling. |
| Makino offers a Die Mold Process training course in our Aurburn Hill office (Detroit) and covers all the areas you are interested in. It's a 3 day course. You get 2 free seats with the purchase of a new machine. If you are buying a used machine, you can still attend the course, but a fee will be required.
__________________ Thanks Frank Adams www.Makino.com |
#11
[QUOTE]Originally posted by hardmill [B] Cutters: It all depends what you want to spend. Obviously the more you spend the better the tools. You want tialn and ALtin coated cutters. Kobelco,Hitachi=the best..... Hi, I would add NS TOOLs to the list Osmo |
| What is high speed machining | Klox | Hard and High Speed Machining | 111 | 01-26-2011 01:21 PM |
| High speed rotary coolant coupling | CAMME | Mechanical Calculations/Engineering Design | 6 | 02-21-2005 09:14 PM |
| What is high speed machining | johnm | Hard and High Speed Machining | 22 | 12-29-2004 05:41 AM |
| high speed rotary table? | jleiwig | Benchtop Machines | 1 | 11-17-2004 10:39 PM |
| High Speed Spreadsheet | MachineSMM | Hard and High Speed Machining | 15 | 07-20-2004 05:41 PM |
