Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 12-11-2003, 12:49 PM
Machine1 is on a distinguished road
Question Drilling .09 thk SS
Just another headache. I am running into problems with my .128 drill that I am using to drill thru 4 .09thk stacked Stainless Steel plates. It is drilling 56 holes and before it gets to the end the drill is breaking. I am running it at 1200rpm with a feed of 7.2. It equals out to .003 per tooth. I am chip breaking at .045". I am using a stub Cobalt drill. I would use carbide but we don't have any in house. Anyone have any suggestions.
Old 12-11-2003, 12:51 PM
Rekd's Avatar
Rekd is on a distinguished road
Can you hear it squeal? If so, you're not feeding it hard enough. Are the corners of the drill breaking/chipping? If so, you are either feeding too fast, or it's having problems getting between the sheets.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-11-2003, 12:59 PM
Before I changed the feed and speed to what it is now...it would make it to the about the 7th hole and it would start squealing. Now since I changed the feed and speed it makes it thru about 50 holes and them starts the squealing... the tip of the drill didn't break down and the drill broke at the top by the holder.
Old 12-11-2003, 01:05 PM
Rekd's Avatar
Are you using standar twist drills? or parabolic? or split point?
You might try splitting the difference between the first feed/speed and the ones you're using now.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-11-2003, 01:10 PM
Im using a split point 135 degree Cobalt Drill. I just didn't think that .003 chip load per tooth was that much.
Old 12-11-2003, 01:35 PM
Rekd's Avatar
.003 isn't too much for the right drill. I would try a standard twist drill, 118° tip. The 135° tips are for softer materials, like plastics and wood.
HTH
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 12-11-2003, 02:05 PM
Boss302 is on a distinguished road
Are you using a coolant?
Old 12-11-2003, 02:47 PM
Flood...
Old 12-11-2003, 03:24 PM
HuFlungDung's Avatar
Moderator
I wonder if the "break-through" disk is what is breaking your drills? In mid stack, if one of these disks happens to get caught between the bottom of the hole and the bit, it effectively caps the cutting edges and snap!
I would try an even more acute angle to the drill, which should be of split point grind, in an effort to make sure it penetrates the next sheet before it has a chance to break out the "breakthrough disk" of the current sheet.
Maybe try not pecking at all, too.
Old 12-11-2003, 10:45 PM
hardmill's Avatar
hardmill is on a distinguished road
I'd bump to about 60 sfm .002 chip load and increase your peck.
Way too much engage/disengage going on.
jm2c
What kind of stainless is it?
PEACE
  #11   Ban this user!
Old 12-11-2003, 11:05 PM
Workhardening S.S.
R.P.M. 948 Feed 2.84 S.F.M. 32 Gives you a .003 chip.
Free machining S.S.
R.P.M 2132 Feed 6.4 S.F.M. 72 also a .003 chip.
Info. from CNCSpeed still one of the handiest software tools I've ever used.
Oh Ver. 5.9.28 gotta get the latest update.
  #12   Ban this user!
Old 12-12-2003, 09:17 AM
Where did you get the CNCSpeed software? Did you download it off of the net
[IMG] code is Off
CNC Router milling / drilling experience where I need help kaleem1 General Metalwork Discussion 0 10-06-2004 02:17 PM
Bolt spacing on THK rail? samualt DIY-CNC Router Table Machines 6 07-24-2004 07:36 PM
Wrong THK rail - Help! samualt DIY-CNC Router Table Machines 10 07-17-2004 02:26 PM
Excellon drilling in Mach2? Rhodan Mach Software (ArtSoft software) 3 04-27-2004 02:42 PM
