| Hard and High Speed Machining Discuss Hard and High speed Machining here! |
As simply as i can put it hsm is taking smaller, lighter cuts at high feedrates. Special tools are required as well as the machines ability to take in the code. Machine also needs to be equipped with an acceleration & deceleration options so it will slow down in tight corners. It doe'nt always require all those variables but then you may lose on accuracy, tool life, etc. An older machine could feasible be used and still gain positive results. Hard machining requires similiar variables. Last edited by hardmill; 03-28-2003 at 11:43 PM. |
| I just went to westec and learned of some software that can be added to any FUNUC control and it will slow down and speed up when needed to make the cut. I will look into it and find some more info on it.
| Hi hardmill, When you talk about H.S.M. does it necessarily mean that the "G" code will be longer? I am assuming so,seeing as you are taking smaller bites of mtl. And is this the same thing that is supported in mastercam? Thanx
__________________ freddie |
Hey freddie Yes the files will be longer and yes its the toolpaths supported by Mastercam. With Mastercams trociodal toolpaths you sometimes need to tweak it a bit to get the result you want but it works fine. If you need any help drop me a line. |
Tool life generally decreases with increased speed. But back in the day, some wiseapple discovered that if you go very fast the tool life is also acceptable (with lighter cuts). One big advantage is that cutting forces are pretty low with HSM, so fairly frail parts can be made with the process. |
#12
| This sounds a bit like the sort of technique we use for machining certain plastics, notably HDPE and certain nylons. REDUCED spindle speed (10,000 to 12,000 rpm or even slower), three or even four flute slow spiral cutters taking shallower cuts at feed speeds of between 10 and 20 metres/min. This gives a nice smooth finish and literally throws out "bullets" from the cutter
__________________ Scrit from the Sunny Pennines, England's Backbone |
| What is high speed machining | Klox | Hard and High Speed Machining | 111 | 01-26-2011 01:21 PM |
| High Performance Machining or HSM | Scott_bob | Polls | 56 | 04-27-2006 03:34 PM |
| High Speed Hard Milling | MachineSMM | Hard and High Speed Machining | 24 | 03-27-2006 07:31 PM |
| High Speed Spreadsheet | MachineSMM | Hard and High Speed Machining | 15 | 07-20-2004 05:41 PM |
| Welcome to high speed machining | CNCadmin | Hard and High Speed Machining | 3 | 03-29-2003 10:45 PM |
