Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 11-17-2003, 07:34 PM
turkgeltz is on a distinguished road
high speed maching h13
Anyone have any experence using 2 flt carbide flat bottom endmills for cutting pockets in h13 steel? And what speeds and feed do you use?
Old 11-17-2003, 07:55 PM
hardmill's Avatar
hardmill is on a distinguished road
What brand tool is it?
I would'nt think a two flt would have the geometry your
looking for to machine H13.
Is it coated? Is it heat treated?
All important variables.
PEACE
Old 11-17-2003, 08:21 PM
Actually I was using a cleveland 2flt coated ticn witha high helix to mill deep pocket up to 2" deep running a .050 ramp, 55ipm witha 7850rpm and it worked quuite well. When the tip would start to get dull the operator would touch it up on the grinder and keep going. Worked quite well. Then they discontinued the tool. Murphys law. Get one that works and poof. Now I'm looking for a replacement.
Old 11-17-2003, 10:01 PM
hardmill's Avatar
I'll look tommorrow and see if I can find you anything.
Is your material heat treated?
PEACE
Old 11-17-2003, 10:12 PM
no, not heat treated just gummy h13. I realize most people don't run them like this, but it worked really well.
Old 02-28-2004, 05:08 AM
camminc is on a distinguished road
See: http://members.cox.net/camminc/MetalMAX Stability Chart H13.pdf
Old 02-28-2004, 05:58 AM
The link doesn't take me there?
Old 04-14-2004, 02:30 PM
Sorry, I messed up.
Go to http://members.cox.net/camminc/
Go to Chart H13 on that site.
[IMG] code is Off
What is high speed machining Klox Hard and High Speed Machining 111 01-26-2011 01:21 PM
High Speed Hard Milling MachineSMM Hard and High Speed Machining 24 03-27-2006 07:31 PM
High speed rotary coolant coupling CAMME Mechanical Calculations/Engineering Design 6 02-21-2005 09:14 PM
high speed rotary table? jleiwig Benchtop Machines 1 11-17-2004 10:39 PM
High Speed Spreadsheet MachineSMM Hard and High Speed Machining 15 07-20-2004 05:41 PM
