Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 05-12-2006, 06:15 AM
serkanc is on a distinguished road
Ge-Fanuc 21imb and HSM
I have a GeFanuc 21imb with the machine Spinner VC560 12000rpm... I want use HSM with G05.1 Q1, as machining there stands "AICC" or "AI NaNo", but shakes more than normal when changing his direction along y or x axis ? Can be there a parameter which help me, or is there any g-code whic must be off if i want to use HSM? Can anyone help me ?
Serkan
Old 09-24-2006, 12:27 PM
Omega is on a distinguished road
Serkan,
For the AICC to work, I think you have to command G49
and the code for higher feed compensation is Q4 (smoothest)...
Q1 is for fastest...
G49 (put this at the beginning of the tool)
G332 R4. (Turn On Ai Nano to tightest level of accuracy)
G05.1 Q1 (accurate arcs)
You must turn off AICC at the end of each tool (before tool change).
Omega
Old 10-13-2009, 08:40 AM
machill is on a distinguished road
Spinner VC560 machining
Please contact Cenk KOC.
At cenkkoc@spinner.com.tr
They can help with your requirement.
very best,
Mac
[IMG] code is Off
