Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 10-17-2003, 09:10 AM
Machine1 is on a distinguished road
Drill & Tap Combination "DRAP"
Anyone used these before? I am having a problem with run a M4-0.7 thru 3/8thk Aluminum. They keep snapping off. Also running 1/4-20 DRAP. Any help would be much appreciated.
Old 10-17-2003, 09:59 AM
Rekd's Avatar
Rekd is on a distinguished road
I've seen them, but have stayed away from them for just that reason. I would think a tool like that would only work on very specific applications. Let us know how you resolve the issue.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 10-17-2003, 10:47 AM
HuFlungDung's Avatar
Moderator
To tap that thickness without a chip clean move ( or three) would be equivalent to tapping 75 mm plate with a 24 mm tap without stopping to clear the chips. You can program two or three G84's in a subroutine to provide the chip break and clearing.
You would be better off to use a seperate tap with a spiral point (for a through hole), or use a cold forming tap.
For deep threaded holes, you are usually safe to increase the tap drill diameter just a whisker, in order to make it easier to cut threads. Unfortunately, the DRAP locks you in to a process with very little flexability.
Old 10-17-2003, 11:18 AM
Yeah that is what I thought I have already changed to a drill and tap. Just not enough clearance.
Old 10-19-2003, 03:25 PM
E-Stop is on a distinguished road
I use them on 11 gauge CRS. Only to avoid a tool change. The part I use them on has 6 1/4-20 holes thru. So I use a DRAP and first drill all 6 holes at 110 SFM then go into tap mode at 60 SFM to tap the six holes. Not much of a time savings but every bit helps.
Old 10-22-2003, 01:47 PM
steele is on a distinguished road
I've used an M4 drap on nominally 3/16" tk. Al and don't ever remember breaking one. I did it to save on tool holders--what's your excuse? I spot drilled with an engraving point but a center drill or real spot drill would work also. I wasn't concerned about location as much as a burr-free, countersunk top surface. I drilled through the part at high rpms, then called a G84 which was ridgid tapping mode. This was a very slow operation since the spindle was always changing speeds or direction. You have to use a drap in a hand fed drill press and a tapping head or in a CNC machine with ridgid tapping! A floating tap holder is not going to be ridgid enough for drilling in a CNC and you can't use a ridgid collet or tap holder in a CNC without ridgid tapping.
Old 02-10-2004, 07:20 PM
the thrill is on a distinguished road
i personally use roll form taps with everything i do... sure it takes 3 holders to spot, drill and tap but youd be hard pressed to find a better tap for longevity i like the feature that mazak added into their m640 where you have a full retract style tapping so you can take depth cuts with a tap for chip clearing... i dont know if any other companies offer this because ive worked solely with mazatrol for the past 5 years with only a little fanuc turning and fadal milling experience prior
Old 02-10-2004, 07:57 PM
WOLOG's Avatar
WOLOG is on a distinguished road
I never use one of those unless the material is less than the length of the drill flutes. I am not sure if those are capable of drilling and tapping at the same time. If they are, I will be surprised.
Good luck.
Old 02-10-2004, 08:00 PM
WOLOG's Avatar
Maybe I should proof read before I hit send. I mean "material thickness< drill flute length"
Old 02-10-2004, 08:01 PM
only way i would ever use a drap in thick material would be if it were a fine thread and i was spinning the tap at like 1300 rpm... like i said before roll form works for me... i can tap at 4000 rpm with a 6-32 tap 3/4" deep with no problem
[IMG] code is Off
Tap Drill Calculator Freeware Rekd Product Announcements & Manufacturer News 35 11-15-2011 05:37 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 10:16 AM
What size of drill bit can be used for 1/2-10 acme tap? starCNC DIY-CNC Router Table Machines 11 04-29-2004 06:36 PM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 08:24 AM
Acme Tap georgebarr DIY-CNC Router Table Machines 14 02-26-2004 12:06 AM
