| Hard and High Speed Machining Discuss Hard and High speed Machining here! |
I've never milled this before. I'm quoting high freq diplexers, 1 x 2 x 8 inches, with tons, (no, really, TONS) of pockets (wave guides), close dia holes, and tolerances all around of ±.002 or less. Where to start for: Tooling? SFPM? How's the machinability? Is it stable? I'm a bit nervous. ![]() 'Rekd
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Afther further review, it seems the Invar 36 and 36 FM (Free Machining) is like 36% nickel? WTF? That's Free Machining?!?!?! ![]() It also seems it's used primarily for it's coeffecient of thermal expansion, (clocks, diplexers etc) I also see suggestions to aneal it for stability. I will end up with about 75% or more material removal (pocketing out the wazoo), is this going to be an issue if I don't get it anealed? Here's a pict of what it's gonna look like. The quantities could be in the hundreds, so I need to nail the cycle times/tooling charges. :edit: The pocketed area you see below is all toleranced at ±.002. ![]() :/edit: TYIA 'Rekd
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by Rekd; 10-14-2003 at 12:34 PM. |
Rekd, Here's a link to Carpenter metals , some info on milling< not much. Maybe you could call them and see if you can get a hold of "smart" app. engineer. Or get your hands an a piece and see how it goes. Better to try it first hand then you will know. http://crswnew.cartech.com/wnew/tech...s/TA00018.html
'Rekd
| Sorry I did'nt get here sooner rekd'. Looks like a nice project ya got there. How big(or small) are the fillets vesus the depth of pockets? If you can send me the file and i'll look at it. I can point you in the right dir. for tools to. BTW what type of machines are you using out there? PEACE |
The doc to dia is about 6 to 1. I've done much worse in alum, brass, and some mild steels, but 36% nickel makes me a tad nervous going that deep. I'll be pre-drilling the corners out. I'll see if they gave me the database yet and send it over. We're using all HAAS'. Hogging = bad ![]() 'Rekd
| Reked the Haas will work just fine. I use to do invar in wave guides on Haas machines worked well.. Just so you know this stuff is abbrasive as heck. Carbide and Cobolt are your freinds.
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Cadcam Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng) |
'Rekd
#10
| I used that typ on cobolt. I would stay with Carbide and go coded like Tiain.
| Machining Invar 36 | Kosta1234 | General Metalwork Discussion | 4 | 02-24-2005 11:03 PM |
| Machining Invar 36 | Kosta1234 | Hard and High Speed Machining | 0 | 02-17-2005 05:01 PM |
