Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 10-07-2003, 10:38 AM
Machine1 is on a distinguished road
Question parabolic drills
Can anyone shed some light on this style of drill "parabolic". Is it a good drill to use in Aluminum? If can you recommend any that would be good It would be much appreciated.
Old 10-07-2003, 11:17 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Machine1,
Yes Parabolic drills are excellent for aluminum or any soft and gummy material.
I use Guring brand and would highly recommend them.
Old 10-07-2003, 11:42 AM
Rekd's Avatar
Rekd is on a distinguished road
+1 WMS.
Para's are da kind! Great chip evac and relief.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 10-07-2003, 01:41 PM
Thank you!
Old 10-07-2003, 02:04 PM
Are you able to get some high feed rates out of these drills when using them on aluminum?
Old 10-07-2003, 02:17 PM
wms's Avatar
wms wms is offline
Moderator
Yes, you can get high feeds. Defiantly higher than standard drill designs.
Old 10-08-2003, 09:24 AM
CDignition is on a distinguished road
Guhring is the best bar none...they are not cheap, but the best on the planet..
Visit my webpage www.cdignition.com
Old 10-08-2003, 09:59 AM
Rekd's Avatar
Heh, that's a pretty bold statement. Have you tried ALL other brands??
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 10-08-2003, 10:54 AM
Do you have any suggestions? I am drilling 3/8 thk 6061-t6 plate. Multiple holes and dia.
Old 10-08-2003, 11:49 AM
HuFlungDung's Avatar
Moderator
For that thickness, I don't know if you would see an incredible difference. You're still going to want to peck anyway, to chip break. A short carbide drill might do a better job, because it is stiffer. Parabolic flutes stand out for deeper holes, IMO.
  #11   Ban this user!
Old 10-08-2003, 12:03 PM
Well I am looking at the parabolic with the stubby FL. Do you think that will make a difference? I sure hope so because I think that they already ordered them. Oh well....let me know.
  #12   Ban this user!
Old 10-08-2003, 01:04 PM
E-Stop is on a distinguished road
Parabolic drills have a wider web to allow better chip evacuation and coolant flow. They work great on aluminum but if you are only drilling 3/8 thick 6061 plate, I doubt that you will notice any significant difference.
Another option is the solid carbide 3-flute drills (I like SGS brand). You can really plow through aluminum with these drills when drill 2XD or less.
HuFlung -- you say that he is going to need to peck anyway to chip break. Do you really think that is necessary on 3/8 thick material? I wouldn't unless the hole size is less than, say, 3/32 or so.
[IMG] code is Off
How much do I have to spend for a good set of drills? Bird_E General Metalwork Discussion 20 06-05-2007 11:26 AM
Koolcarb Coolant fed Drills Machine1 Hard and High Speed Machining 2 02-05-2004 01:08 PM
