Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: parabolic drills
  1. #13
    Registered Rekd's Avatar
    Apr 2003
    teh Debug Window
    Originally posted by E-Stop
    Parabolic drills have a wider web to allow better chip evacuation and coolant flow. They work great on aluminum but if you are only drilling 3/8 thick 6061 plate, I doubt that you will notice any significant difference.
    Another option is the solid carbide 3-flute drills (I like SGS brand). You can really plow through aluminum with these drills when drill 2XD or less.
    HuFlung -- you say that he is going to need to peck anyway to chip break. Do you really think that is necessary on 3/8 thick material? I wouldn't unless the hole size is less than, say, 3/32 or so.
    +1 on the 3 fluters. You can almost RAPID thru the part with those sucka's
    Also, Agreed on the pecking in 3/8 with anything less than .100 or so.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  2. #14
    Sep 2003
    TULSA, OK
    So what kind of C-SP should I start out with using the parabolic drill. I am using .1285 - .438. Any suggestions would help
  3. #15
    Apr 2003
    teh Debug Window
    I would start around 600-800 and work your way up. The bigger the tool, the heavier the chip load. I've run para's in alum at over 1400 SFPM with good results.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  4. #16
    Sep 2003
    TULSA, OK
    You must of had some incredibly high spindle speeds?
  • #17
    Apr 2003
    teh Debug Window
    I believe I was running a drill just over .500 dia, at around 9,500 or 10,000 rpm. I was going like .750 deep, no pecking, feeding at like 125 ipm.
    You could barely see from the steam. The drill looked like it was rapiding into the hole. The chips were around .015 thick. It was beautiful..
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  • #18
    Sep 2003
    TULSA, OK
    Thats awesome!
  • #19
    Jun 2008
    I was Googling around and came across this thread.
    I'm looking at running some small parabolic drills into some 316 Stainless. Any idea on how affective this would be? The size I'd be using would be a #32 drill (0.116"), drilling to a depth of 1.300".
    Everywhere I look I hear these are great for aluminum, but I was hoping that the parabolic design would help with chip extraction due to the depth of the hole.
  • Page 2 of 2 FirstFirst 12
    1. How much do I have to spend for a good set of drills?
      By Bird_E in forum General Metalwork Discussion
      Last Post: 06-05-2007, 11:26 AM
    2. Koolcarb Coolant fed Drills
      By Machine1 in forum Hard and High Speed Machining
      Last Post: 02-05-2004, 01:08 PM
