Gold Member
Help. Looking for a video posted a while ago..
Does anyone remember a video link that was posted here on cnczone, that showed Aluminium being CNC machined. It was a company video. The Alu plate being cut, looked to be about 1/4 - 1/2 inch thick. it was 2D, maybe 2.5D milling. The cutter cut right through in one pass. (small diameter cutter, high speed), and coolant was pumped in from two directions alternately. As the head travelled left to right, the coolant was fed from one tube (locline), and for right to left, another tube was used. It looked like a back plate or something similar was being cut for a control box, a bit like the back panel of a PC. I'm sure at the end of the video, a name or logo was engraved on the piece.
Does anyone remeber this video? I'm sure it was a link that was posted, to a companies site. They had other CNC videos too.
Please help me find it again, if you can.
Thanks.
Regards Terry.
Was this the one?
Mr. Bean,
I believe this is the video you're looking for, it's from Daytron Dynamics, Inc.
and the video can be seen here:
http://www.datrondynamics.com/VideoZ...HighSpeedH.wmv
It's darn impressive!!! (even if it isn't the exact one you're looking for)
HTH,
HayTay
P.S. The link to the original CNCzone thread is here:
"Gol-Matic" mills; interesting setup
Reason: Provided link to original CNCzone thread reference
Gold Member
Thanks. That's the one. I remembered it slightly differently. Maybe there's a few kicking around, but that's definately the same part being cut that I remember.
Many thanks. I've been looking for it for two days now.
Regards Terry.
Gold Member
That was the "exact" video I have been looking for. The rest of the machining videos can be seen here:
http://www.datrondynamics.com/videozone.htm
This page has the detial, engraving and thread milling videso too.
Thanks again.
Terry.....
I know you have already found your video. But I just found some interesting movies at http://www.cronsrud.com/ if you follow through to cnc router link -> video -> special applications there are some aluminum machining videos among other materials.
Gold Member
WOW! What else can I say. Who knew it was possible to machine material that thick in one pass and with such a small diameter bit. WOW!
