Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 08-21-2003, 04:29 PM
Bill is on a distinguished road
Question machining O-1
I am getting ready to set-up a job that will be cut with a 1/32 4flute carbide endmill, total depth .05. I am running a HAAS MINI MILL. What is a good starting point for speed & feed, the material is in soft state.
Thanks, Bill Johansen
PS as you can tell I bounce from job to job, so had to break down the set-up for reamer testing!
Old 08-21-2003, 04:36 PM
hardmill's Avatar
hardmill is on a distinguished road
First off...
Whats top end on your spindle?
How good are you holders?
What type of toolpath are you using?
Cool that will get us started.
PEACE
Old 08-21-2003, 06:18 PM
5000 rpm
holders good shape, if i have will buy new
.tap file from bobcad v15 and hand programming
Old 08-21-2003, 06:30 PM
hardmill's Avatar
max...
Max out your spnidle thats for sure, even @ 5000rpm
Thats only about 40sfm.
With a .0005 ipt your looking at 10ipm.
I'd go for .003-.005 step over or d.o.c.
Also in the future i'd steer clear of the 4 flute tools.
Look at robbjacks 2 flute (TiAln) coated tool they're
geared for just such applications.
PEACE
Old 08-22-2003, 12:10 AM
Smile
Hardmill thanks for the info, I was not even close my depth was .010, step over .010, rpm 2500 & feed 2.0 ipm. I will give it a try in the morning.
Thanks again, Bill Johansen
Old 08-22-2003, 12:15 AM
hardmill's Avatar
What does the geom. look like that your cutting.
I'm assuming its pretty small.
PEACE
Old 08-22-2003, 09:57 AM
Hardmill the part is1/2 square by 1 long it is used for insertion of terminals, there are 3 irregular shaped islands. Also we have Solidworks & are loking at Camworks, the engineers have the say so for the software, they say need something that runs in Solidworks.
[IMG] code is Off
Machining rubber HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 10 05-01-2011 04:59 PM
High Performance Machining or HSM Scott_bob Polls 56 04-27-2006 03:34 PM
Machining 2219-t4 aluminum scottwally General Metalwork Discussion 2 06-18-2005 11:53 PM
Reintegrating machining in our company beast General Metalwork Discussion 18 03-24-2005 08:51 AM
aluminium and steel machining Hobbiest General Metal Working Machines 3 02-08-2004 10:59 PM
