Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 08-20-2003, 02:57 PM
Rekd's Avatar
Rekd is on a distinguished road
Feed/Speed Milling Alum
I'll be using a .312 Carbide EM, 2 flutes, 1/2" LOC, going 1.75 deep. (Fins for a heatsink).
I'm starting at 7,000 RPM, feeding at 100 IPM with .075 DOC. That's about a .007 chip load.
Is the DOC too deep for these feeds? Can I go deeper? (That's a loaded question.. ) Should I speed up the feed and decrease the DOC more?
'Rekd teh High Feed n00bie
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 08-20-2003, 03:06 PM
hardmill's Avatar
hardmill is on a distinguished road
I say it looks good as long as the fins are'nt too thin.
If they are do like you said and decrease d.o.c..
PEACE
Old 08-20-2003, 03:12 PM
Rekd's Avatar
The fins are .078 wide, 12" long, 9 of them. I'll be doing it by depth, (machining all fins to first depth, then all fins to second depth etc), so that will help with deflection.
Thanks!
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 08-20-2003, 04:20 PM
hardmill's Avatar
Sorry 'bout the delay.....
i'd say your good to go.
PEACE
Old 08-22-2003, 05:39 PM
Rekd's Avatar
Fired that puppy up today. Sang me a song of happiness and contentment. Who'd of thunk you could run a tool with a length 6xDia at 100 IPM..
I could prolly run it up to 150 and drop the depth down to .05, but I dont wanna push it too much.
Thanks meng!
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 08-22-2003, 05:54 PM
hardmill's Avatar
Way cool...
Any time boss
PEACE
Old 10-25-2003, 08:09 PM
camminc is on a distinguished road
See this link for answers on speeds and feeds for HSM: http://www.cnczone.com/showthread.ph...4220#post14220
Old 11-26-2003, 10:55 PM
Scott_bob's Avatar
Mfg Engineer
Scott_bob is on a distinguished road
Is this HSM?
Re.
Just wonderin if this feed rate is what is considered HSM?
What kind of CNC?
Do you have more RPM? This is only 572 sfm...
I imagine though that your tool is hangin out of the holder 1.8"
So I would be surprised if you got good results.
I wonder if it would be worth using 2 tools, one stubbed, the next extended...
T1 could go much, much faster that way. You should be able to go straight (as I imagine a heat sink) real fast say 400 ipm
Just a thought,
Scott_bob
[IMG] code is Off
Milling Aluminum InventIt General Metalwork Discussion 20 12-05-2011 07:20 PM
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
Recommendations for a practical and complete S/W combination for simple 2d Milling ngr1 General CAM Discussion 6 01-10-2004 06:36 PM
