Results 1 to 5 of 5
Thread: 135 Degree Split Point Drills
    Registered Crashmaster's Avatar
    Mar 2007
    Hey Folks,
    was looking at ordering these 135 degree split point parabolic drills manufactured by Titex. Was wondering if these need to be spot drilled first and if so what angle spot drill. I can't seem to find any spot drills over 120 degrees.
    Thanks,
    CM
    Feb 2011
    Ireland
    I assume your talking about carbide drills. Generally the bigger size carbide drills - no - don't bother spot drilling. if your talking about the likes of drills from 1.5mm down, i would spot drill yea. WNT have an 142 degree carbide spot drill in their catalog. www.wnt.com. Well thats my opinion anyway.
    Mar 2007
    Thanks Marcutous. The smallest one I'm using is a 1/16" (about 1.59mm.) I am expecting the drills today or tomorrow, I'll let you know how it goes.
    Registered chippslinger's Avatar
    Nov 2008
    I use Titex drills every day and do not spot any unless under 1/16
    Feb 2006
    If you have any issues or concerns with location or drift on longer drills, try a 2D deep pilot hole with a carbide screw machine length drill of the same point angle.
    Again this would only be needed with small diameter drills and/or jobber and longer length drills.
    1. Just IN- Carbide Drills 3x 5x 8x Diameter Drills
      By CDTooling in forum Product and Manufacturer Announcements
      Last Post: 09-10-2010, 09:37 AM
    2. can't split big model
      By 15mgtar in forum Rhino 3D
      Last Post: 03-20-2010, 11:21 AM
    3. Split/NCS
      By gplush in forum General CAM Discussion
      Last Post: 11-05-2009, 05:56 PM
    4. There's Drills, Mills and Mill/Drills so what's the....
      By JWB_Machining in forum General Metal Working Machines
      Last Post: 05-20-2009, 10:04 AM
    5. Replies: 3
      Last Post: 06-29-2008, 08:30 PM
