Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Hard and High Speed Machining
Hard and High Speed Machining Discuss Hard and High speed Machining here!
Old 07-16-2003, 05:05 PM
Mortek is on a distinguished road
feeds and speeds
What kind of feed would you use with a 1/4 ball mill 4 flute at 6000 rpm spindle speed in 7050 aluminum T4
Old 07-16-2003, 05:11 PM
Rekd's Avatar
Rekd is on a distinguished road
48 IPM at .002 chip load, or 96 @ .004
Chip Load x RPM x Flutes = Inches Per Minute
'Rekd teh Machine Shop 101
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 07-16-2003, 05:12 PM
Rekd's Avatar
Of course, this will depend on the depth of cut you plan on taking. Deeper cuts = lower CL
'Rekd teh afterthought
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 07-16-2003, 06:06 PM
what would you recommend. Right now I am taking .005 DOC per pass on z level finishing, I need the 1/4 for the radii to be right in the corners. But I also am spindle 3500 rpm 45 ipm feed at the .005 depth.
Old 07-16-2003, 07:10 PM
Rekd's Avatar
If you're only doing .005 deep, wind it up as fast as it'll go, RPM and Feed. (Don't feed faster than your machine can handle.)
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 07-16-2003, 09:25 PM
CAMmando's Avatar
CAMmando is on a distinguished road
+1
I would program at 80 IPM
start at 50% Feed over ride on machine and work up.
THIS ASUMES THERE IS NOWHERE ON THE PATH THAT WILL ENCOUNTER HEAVIER CUTS SUCH AS POCKET WALLS.
If you get chatter while increasing the feed, dont be afraid to increase the feed through it.
Are you cutting exactly on tool center or up the radius ? If you are going over hills and through valleys you may experience chatter as the point of contact moves past the tool center.
CAM
Wee aim to please ... You aim to ... PLEASE.
Old 07-16-2003, 10:07 PM
The endmill is hanging out about three inches would that make any difference? Nothing really in the way until the bottom of the part where the floor is on a compound angle. Gotta love those engineers.
Old 07-16-2003, 11:16 PM
HuFlungDung's Avatar
Moderator
Yikes, 3" overhang with a 1/4" dia tool is a lot. You couldn't talk 'em into letting you do it with a bullnose cutter? ( I know, you get modified corner radii)
I agree, engineers!! They tend to pull numbers out of thin air with n'er a thought for how it gets cut. And then they whine because it costs so much.
Old 07-16-2003, 11:43 PM
Rekd's Avatar
+2
'Rekd teh Engine Ears
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 07-16-2003, 11:59 PM
CAMmando's Avatar
3" overhang ... ignore my previous post unless you like "the flight of the bumble bee"
Probably will wind up back at lower RPM and feed due to Vibration.
Your gonna have to play at the machine.
Are you using carbide ? If not look at the "Tuffy" style ball mills, Carbide, with short LOC.
Some other thoughts ...
If your going up against walls, have the shank ground .005 under behind the cut. If there are no walls, try finding or making an extension (holder).
Old 07-17-2003, 12:09 AM
Moderator
Mortek, maybe you'd have the best luck if you just shut the spindle off and drag the cutter over the part
  #12   Ban this user!
Old 07-17-2003, 12:30 AM
hardmill's Avatar
hardmill is on a distinguished road
Golf clap Hu!!
PEACE
[IMG] code is Off
feeds and speeds program Kees Soeters General Metalwork Discussion 3 05-12-2005 01:32 PM
feeds and speeds lito General Metalwork Discussion 4 03-14-2005 08:58 AM
Speeds and Feeds for Beginners and Technical Reference Rekd Mechanical Calculations/Engineering Design 10 01-27-2005 09:35 AM
feeds speeds and cutting tools replicapro General Metalwork Discussion 4 09-14-2004 01:22 PM
feeds and speeds Mortek Hard and High Speed Machining 6 02-28-2004 04:59 AM
