Results 1 to 10 of 10
Thread: CAM for HSM - Pro-Man??????
    Mar 2003
    m
    Any ideas on the best CAM to use for HSM applications and what do you think of Pro-Man?
    Registered Rekd's Avatar
    Apr 2003
    teh Debug Window
    Never used ProMan.
    Mastercam has a very nice set of features for HSM.
    'Rekd teh biased
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Sep 2003
    ca
    pro/man supports hsm. constant load, follow hardwall etc. i like pro/man hsm more than mastercam hsm. i've used them both. hope this helps.
    Moderator JIMMY's Avatar
    Mar 2003
    united states
    sorry, i have never used proman before. I use MasterCam and enjoy it very much. I use it everyday and like the options in MasterCam. Sorry I was not any help, just letting you know what I use.
    Registered hardmill's Avatar
    Mar 2003
    There is also a new HSM c-hook for MCAM. Very nice indeed.
    http://www.cimco-hsm.com/
    PEACE
    Registered HomeCNC's Avatar
    Mar 2003
    Proman did not score very well in my benchmark at work. We now use PowerMill and it runs HSM great!
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Mar 2003
    m
    Pronc,
    Are you using Pro-man daily in your work or are you an occasional user. What is the type of work you are using Pro-man for?
    Klaus
    Registered Gibbsgod's Avatar
    Jul 2003
    Eastern US
    More for HSM
    In the past I have used Tebis, Pro Man, UG and Cimitron. Of them all Pro Man would rank last with ug or Tebis on top.
    This was for 3D applications. Mold and Die. If you need to do true HSM 600ipm+ then all the lower end applications (masterCAM, SurfCAM, GibbsCAM etc...) would not be a choice of mine.
    To that list you can also add Work NC and Powermill. Both have a very good range of HSM options.
    A good thing to do if you are serious about HSM is to add VersCut with all the optimizers. These work FAR better than anything that the cam programs can do and you can optimize output from all cam softwares.
    Sep 2003
    ca
    Klaus,
    i use pro/man everyday. here at work they consider me as "super user" or whatever the hell they mean by that. i use it for everything from prototyping casting, plastic injection mold part to production and tooling. oh did i mention tooling design too? regarding hsm, the new rough and rerough in wildfire is awesome. with contant load option and scallope control on you are really high speed. hope this helps.
    May 2004
    never Proman
    I had on my PC for many years is ok for simple stuff but not daily use.
    It works for you but not for me I like old Cimatron IT.
    And new what I like to get is Topsolid cam.
  • Posting Permissions
