135 Degree Split Point Drills
Results 1 to 5 of 5
Thread: 135 Degree Split Point Drills
    Registered Crashmaster's Avatar
    Mar 2007
    Default 135 Degree Split Point Drills
    Hey Folks,
    was looking at ordering these 135 degree split point parabolic drills manufactured by Titex. Was wondering if these need to be spot drilled first and if so what angle spot drill. I can't seem to find any spot drills over 120 degrees.
    Thanks,
    CM
    Feb 2011
    Ireland
    I assume your talking about carbide drills. Generally the bigger size carbide drills - no - don't bother spot drilling. if your talking about the likes of drills from 1.5mm down, i would spot drill yea. WNT have an 142 degree carbide spot drill in their catalog. www.wnt.com. Well thats my opinion anyway.
    Mar 2007
    Thanks Marcutous. The smallest one I'm using is a 1/16" (about 1.59mm.) I am expecting the drills today or tomorrow, I'll let you know how it goes.
    Member chippslinger's Avatar
    Nov 2008
    I use Titex drills every day and do not spot any unless under 1/16
    Feb 2006
    If you have any issues or concerns with location or drift on longer drills, try a 2D deep pilot hole with a carbide screw machine length drill of the same point angle.
    Again this would only be needed with small diameter drills and/or jobber and longer length drills.
