Results 1 to 3 of 3
Thread: 5/32 endmill holder
    Wanna be
    Mar 2004
    5/32 endmill holder
    Does anyone know where I could find a 5/32 end mill holder for an R8 taper machine? I would like to use one for predrilling 10-32 tapped) holes in some aluminum. Due to the tool changes I will be doing, I would like to try the endmill holders to help preset the length of the tools.
    Dan
    Check out what I am working on at www.routerbitz.com!
    Registered mc-motorsports's Avatar
    Feb 2007
    ER11 collet holders is probably the best your going to do. Unless you get a 1/8" EM holder and bore it open.
    MC
    Mar 2008
    An R-8 collet in 5/32" size is not at all uncommon. You should be able to buy one from just about any industrial supply house. Fair warning though, if you're using a carbide end mill, you'd better get a high-quality collet, such as a Hardinge, to assure minimal runout.
  1. 1/8" shank endmill holder
    By CNCMike in forum General Metalwork Discussion
    Last Post: 10-23-2008, 11:58 PM
  2. Router Bit or Endmill
    By cncneo1 in forum WoodWorking
    Last Post: 01-13-2008, 04:11 PM
  3. No Endmill Holder
    By DroopyPawn in forum General Metal Working Machines
    Last Post: 11-20-2007, 10:14 PM
  4. Endmill bit and holder.
    By ihkim in forum General Metalwork Discussion
    Last Post: 07-26-2005, 02:38 PM
  5. Endmill runout
    By dberndt in forum General Metalwork Discussion
    Last Post: 01-28-2005, 12:26 AM
