Hmm, yeah good point!
It was literally that Dad came home one night with a bag full of motors, gearboxes, controllers, and cases and said "Andy, I've got a project for you". Most of the bits didn't work or were for different drills and the case is a bit rickety, but apart from that it works fine. I also have a few motors and gearbox bits left over - some of which found their way into my A-level Design Technology project!
Unfortunately the speed controllers had capacitors across the power terminals to protect the circuit from voltage spikes and stuff and on two different speed controllers these capacitors decided to explode, which was very scary!
The drill cases say "Edge" on the side, but I've searched for "Edge drills" and similar things on the internet and nothing came up. I don't mind if it's a dodgy make though, as long as it doesn't kill me...
LinkBack URL
About LinkBacks
I believe if you can make it do, and if you cant then learn how! ......
But hey, I'd love to make my own tools for working after hours. Any more info on the 18V? Was it badly in need of repair, or was it literally 'bits' that ended up sticking together and coming to life?
L8rs.
