Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Mills > Haas Visual Quick Code
Old 04-20-2009, 02:22 PM
cdfracing is on a distinguished road
Quick codes for slots
Hi Guys,
I have now owned my new haas mini mill for about two weeks now and think its great , however I have recently been finding it hard to program kidney slots,
does anyone have a program for quick codes I can load in?
I.e will need to know ...
how many slots ...i.e 5
pcd i.e 60
angle + and minus 10
feedrate , depth extra
thanks
Old 04-20-2009, 03:00 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
I know the Haas quick code does pockets but Kidney Shaped Slots might not be included.
Maybe someone has a Macro?
Does your new vmc have the macro option?
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 04-20-2009, 03:45 PM
Mmm , not sure .... still playing about with it. I could of done with rotation scaling option but it doesn't have that either
Old 04-20-2009, 11:27 PM
tobyaxis's Avatar
Moderator
Have you given CAD/CAM software any thought? Off line programming can be done anywhere at any time. It is more efficient with great accuracy.
Toby D.
Schwarzwald
Old 04-21-2009, 05:18 AM
I have but where can I get the best deal?
Old 04-21-2009, 09:31 AM
You can turn on both Macro and Rotation & Scaling options for a 200 hour trial period. If you turn them off again the 200 hours can be stretched over a long time.
Just find them in Parameters; there should be a 0 and T beside them. Turn off Setting 7, push E-stop and with the curosr on the option type 1 and press write.
Old 04-21-2009, 12:50 PM
I did try that but the trial had already expired..... it already had the T next to it even though I never used it!
Old 04-25-2009, 03:16 AM
Caue's Avatar
Caue is on a distinguished road
cdfracing
I'd be glad in help you. So, let's start: first of all, I need to know what a hell is a "kidney slot" (please e-mail me caue.nascimento@bol.com.br with drawings and variable dimensions for your parts). Once I know it, probabilly I can provide you an additional file to VQC with the new pattern. Please send your software version and VQC version. Maybe I'll need the machine backup data, if you don't know how to do this, I can also help you (first of all I need to know the software version to give you the best way of doing this).
About macros, just type at edit mode #1 at the comand prompt and type <write/enter>. If a message "BAD CODE" appears, you DON´T have macro options installed. If this is the case, call your local dealer and think about acquiring this usefull software option.
Since now, thanks for choosing Haas Automation!!
PS: I'm not from US (I'm in Brazil), that's why the most difficult is about the language (the "kidney slot").
Old 05-01-2009, 06:35 PM
mcs mcs is offline
mcs is on a distinguished road
Hi Caue, I have a 2007 TM-1 and use the VQC alot and would like to see it expanded. I use the machine for making jigs and fixtures. I bought the machine thinking it would replace my manual bridgeport for alot of the basic stuff like squaring up and side milling. As it turns out, the standard vqc does not support these operations very well.
Is it possible to write a template to side mill or profile or frame mill using multiple cuts, putting the cut on the x/y axis rather than stepping down in th z axis?
Have you done anything like this?
Old 05-02-2009, 12:13 AM
Caue's Avatar
Anything is possible to be done about VQC programming, once it's file like any other one. You just need to pull out VQC template (at List Prog), using USB, than you can edit some template according to your needs (using Windows notepad or similar text editor - as plain text, not rich text) and load it again.
Try it and post or e-mail me for any doubts.
Cheers, and thank you for choosing Haas Automation!!
Haas Quick Codes MetalMolder Haas Mills 3 04-27-2008 09:16 PM
M-codes and G-codes 4 Matsuura ES-1000V maximusek G-Code Programing 2 11-27-2007 07:41 AM
T slots in MDF?? JerryFlyGuy DIY-CNC Router Table Machines 26 03-10-2007 11:30 PM
Machined T-Slots? SpookyDad DIY-CNC Router Table Machines 6 07-16-2006 09:37 PM
T-slots 4x8 - One side done samualt DIY-CNC Router Table Machines 13 06-07-2004 11:47 PM
