| changing the std file how do we load a changed 9997 file into the machine? (or a new template) we have the VQC loaded on a desktop comp as well as on the machine, and have made a modified file that we would now like to load into the machine. but we get a macro load error when we try to copy over. we cannot see the original 9997 file in the prog list either. is the a setting or pram we need to change to be able to copy it in? thanks |
| Do you have the manual? There is a setting that makes 9000 numbered programs visible. You need to turn that on. |
| Settings 8 - Prog Memory Lock must be OFF 23 - 9xxx Progs Edit Lock must be OFF 74 - 9xxx Progs Trace must be ON for graphic simulation purposes only 75 - 9xxxx Progs Singls BLK must be ON for safety reasons In addition, ALWAYS backup machine data BEFORE uploading anything to the comand. If you have any doubt about how to do this, please post me your doubt and machine's software version. Last edited by Caue; 04-25-2009 at 04:19 AM. |
| Thread Tools | Search this Thread |
| converting a mastercam 9 file into a Solidworks file | Michael82 | Solidworks | 5 | 04-17-2009 02:14 PM |
| Need Help!- Need a favor. STL converted to part file or solidworks part file. | Cmzwirner | Solidworks | 3 | 12-11-2008 08:45 AM |
| Changing file names | CNCMike | Solidworks | 4 | 08-13-2008 09:44 AM |
| changing unit of measure of imported file | Joe Miranda | BobCad-Cam | 3 | 12-13-2007 03:28 PM |
| Changing CS | fastolds | GibbsCAM | 2 | 02-02-2005 01:31 AM |
