Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Haas Mills > Haas Visual Quick Code
Old 11-20-2007, 05:34 PM
ddk114 is on a distinguished road
Question Haas Coordinate Rotation G68
Any experts out there?
VQC external corner probe saves values in an offset like G54, in addition to values in variables #185, #186, and #189. Line G68 X#185Y#186R#189 calls those variables as a point of rotatation and angle when entered into code. This, I believe, is true and correct. I'm not so sure that there isn't a problem elsewhere.
My testing has shown that a pre-existing number in the G54 offset will be subtracted from the new G54 actual, and input into #185 and #186 variables. Run external corner probe again, the variables approach zero, your offset values will remain the same. It does seem to follow its path if you verify that these numbers approach zero, it's off maybe an inch otherwise.
The object of this exercise is to make it unnecessay to indicate everthing straight on the table. It's kind of difficult to move something that has been tacked down with carpet tape.
Do I have a point or have I driven myself crazy? Any suggestions or additional verification would be helpful.
Thanks in advance.
Old 02-19-2008, 02:48 PM
Probe Guy is on a distinguished road
Gathering G68 data from Probe
Hey there,
I ran accross this post from a few months back. Did you resolve your questions about the G68? If you did, great! If not, of if you have other probing questions we are as close to experts as it gets. We are a Renishaw RDI that specializes in custom and difficult probe applications. Drop us a post or call our office directly if we can help. HTI Inc. 406-883-5651
Good Luck!
Renishaw Coordinate Rotation gplush Haas Mills 0 10-14-2007 06:27 PM
Haas G54 - G60 Work Coordinate Offsets truline Haas Mills 8 09-04-2007 04:51 PM
G68 Coordinate Rotation System ebigfoot2 Fanuc 2 08-13-2007 08:33 AM
coordinate system kiethnt G-Code Programing 6 04-26-2007 08:46 AM
Using 3d Coordinate Conversion On A Vf4 renglish Haas Mills 3 02-02-2007 12:04 PM
