Hello and help please. I went to turn on my mill today and at start up I got 219 Z Phasing Error I cleared it started spindle warm up and the computer beeped screen went black and the computer started up again. Shut the machine down opened the back had turned the machine on again in the same way and watched the phasing lights in the back of the machine. The computer reset again but all 3 phase items stayed green just the single phase components stoped. Repeating the process trying to look at parm and set each time the computer resets the error changes from 219 217 and 218 Z X and Y phasing errors, not in that order seemingly random. I am at my witts end any advice would be helpful
__________________ I'm not lazy..., I'm efficient! HAAS GR-408 |
| You may have a low voltage power issue. Check to see if the circuit boards at the upper left corner have proper low voltages. ie. +12vdc, -12vdc, and +5vdc. If the voltages get to low it will cause electronic issues especially on the mocon pcb and give out seeminly random alarm codes. If these are ok then I would advise you call your local service tech as haasmanuk said. Let us know what you find. |
| So to confirm what your problems are- the items on the machine that use three phase are running ok even though you get phasing errors on startup? So X Y and Z axes zero out and run ok? and spindle runs ok? Yet single phase items i.e coolant pump, fans, chip motor, CRT (monitor)do not function correctly? If this is correct then maybe you should be checking your in coming power to machine - maybe you have lost a phase? If not then HAASTEC could be pointing you in the right direction with checking The low volt power +5 -12 +12v Hope this helps |
| Need Help!- Errors #1,#16,#17 | masterfabr | Fadal | 9 | 01-13-2010 08:55 PM |
| mazatrol t1 errors | beno | Mazak, Mitsubishi, Mazatrol | 7 | 10-05-2009 05:21 PM |
| Need Help!- Getting 2 Errors.... Someone Please!! | DesKitchens | Commercial CNC Wood Routers | 0 | 09-14-2009 08:30 AM |
| Input Phasing; Pass/Fail | Geof | Haas Mills | 3 | 06-25-2008 11:01 PM |
