Old 02-18-2010, 01:20 PM
juxtoposed is on a distinguished road
How many work offsets will my haas control recognise?
YOu know like G54, G55, ECT?
Thanks.
Old 02-18-2010, 02:40 PM
It depends on the age of the machine.
Older machines with the CRT monitor recognise G54 to G59 and G110 to 129, newer machines have many more available b ut I don't know the actual number.
In practise, however, if you use a G10 command you can relocate any work zero on the fly in a program so you can have an unlimited. Also you can set a single main work zero and then use G52 to create as many secondary work zeros as you like.
Old 02-18-2010, 06:17 PM
Delw is on a distinguished road
Geof,
can you post that link to the g10 command that has examples ( I know you posted one a while back just cant find it and I am lazy
I have 3 vices and didnt want to write one program to fit all so I used
g55 g56 g57 etc etc for each part ( 5 parts at a time)
it was an easy edit ( program I had before was for one at a time 10 parts total, now I have 200 parts total so I did 5 at a time) for the program kinda it had 7 tools but I am thinking the g10 would have worked better/easier to program. or at least a sub but I suck at writing subs with out a working example.
Delw
work offsets porkchop21 Bridgeport and Hardinge Mills 1 09-24-2009 11:39 PM
Work Offsets RMT Mach Mill 14 12-14-2008 09:49 AM
Haas G54 - G60 Work Coordinate Offsets truline Haas Mills 8 09-04-2007 03:51 PM
Problem with work offsets and Acromatic control acromastic CamWorks 3 06-26-2007 03:18 PM
work offsets 5axisdan Mazak, Mitsubishi, Mazatrol 0 07-04-2005 10:17 AM
