Old 02-11-2010, 11:36 AM
fastfrank is on a distinguished road
PM Belleville washer replacement
Greetings All,
1994 VF4 with a zillion tool changes.
I have looked in past threads and didn't seem find the answers to my question.
I will have small window of down time and would like to do some preventive maintenance since I run this machine hard using a 1/2 carb mill like a band saw in 1/2 aluminum plate. Could I ask for your experience for parts (hopefully cheaper than HFO) and for any "need to knows" for belleville washer replacement so I can hopefully complete the job the same day I start.
Thanks in advance
Frank
Old 02-11-2010, 12:23 PM
underthetire is on a distinguished road
Don't know what size you need, but keybellvile is the cheapest place to get them.
Old 02-11-2010, 01:03 PM
murphdog is on a distinguished road
Frank,
I have done this on a 99-VF2. It was not holding tools tight in the spindle anymore. Upon dissambly about 60-70% of the washers were in pieces. What I can remember is: When you pull the drawbar assembly out, do so carefully so all the pieces do not fall apart. This way you can get a head count of how many washers are needed. I just measured the diameter and thickness and called MSC for bellville washers. When reassembling, the 4 balls that hold the tool need to be in place before putting the drawbar back into the spindle. I had to make a tool with windows to be able to compress the springs and get the keeepers back in place. The springs are held in a compressed state by what is basically an overgrown version of an automotive valve spring retainer and keepers. I borrowed the drawbar tension tester from my HFO. When I checked what I had done I was 75-100 pounds under their spec but have been running 2 years since with no problems.
Murph
Old 02-11-2010, 01:07 PM
I have the digital command gauge, and a clamprite gauge. They will vary 100 LBS depending on the machine. Thats normal, since the gauge line may be off a little. I recommend every shop with more than 2 mills get the clamprite set up. It's good PM
Old 02-12-2010, 07:19 AM
Thanks All,
You guys have been a lot of help. With your help there is no telling how much $$ has been saved by average Joe's like me who are not afraid to climb in and turn a wrench. After receiving a few experienced tips, as long as a guy pays attention, it just nuts and bolts!
By chance does any one have their paperwork handy to see what washers were used so I could maybe have the correct ones in hand before I start?
Thanks again!!
Old 02-27-2010, 07:15 AM
mniadna is on a distinguished road
FF,
If you tell me the part # of your drawbar, I can tell you how many springs it is supposed to have. I have a spreadsheet Haas sent me. I have a 1997 VF-0 with drawbar #30-3410D, it has 79 springs and is supposed to have 1200-1450LBS of pull. I believe almost all of the 40 Taper VF-Series 7.5k RPM spindles are the same. Haas only sells the drawbar assembly. I am a 100LBS below spec. I plan on just replacing the springs. I just did this in my Fadal.
Fixed Bearing w/ Belleville washers CNCDevil Linear and Rotary Motion 19 04-16-2012 08:44 AM
Problem- Belleville spring washer replacement Fadal Error Fadal 38 02-27-2010 10:25 PM
PP Washer clembrant Employment Opportunity 24 02-03-2010 08:41 PM
Belleville washers on ball screws Robin Hewitt General Metal Working Machines 4 02-19-2009 11:36 AM
Seal/Washer In UNIVER Valve Type AE 1001 Replacement On Bridgeport Help!! Huntersyv Bridgeport and Hardinge Mills 1 02-07-2006 01:02 PM
