We have a 1999 Haas VF-3 with a side loading pallet changer and recently started getting some vibration problems when facemilling or taking a heavy cut. Is there any way to adjust/measure the clamping pressure on the pallet? I bought a service manual but it doesn't give a clue when it comes to the clamping component of the pallet change system. Thanks in advance. Wganders |
Actually, the bearings would be the problem but since you have to replace them as a set I just referred to the rails being bad. When you rapid the Y axis the table really vibrates, sort of like its stuttering. Also, if you put a lot of way lube on the rails and then move the table back and forth there will be an oil impression of a bearing about every 1.5 inches. Does all this add up to bad bearings? |
| Not really sure what you mean by 'an oil impression of a bearing about every 1.5 inches'. Have you looked at problems with leadscrew or support bearings or bearing pack? Any one of these could give you the vibrating that you describe. Also, have you checked y axis servo amp and/or Low Volt Power Supply that feeds servo amps? The amp or the PSu could give you bad vibtrations too. Hope this helps |
| Tags |
| haas, mill, pallet, repair, vertical |
| Cincinnati with pallet changer | peterson76 | General Metal Working Machines | 1 | 01-27-2010 07:34 AM |
| Pallet Changer | MIDDEN300 | CNC Machining Centers | 5 | 09-20-2008 08:32 AM |
| Fanuc pallet changer | Derek.C | Fanuc | 3 | 09-19-2008 09:29 AM |
| Pallet Changer for a Fadal | Delw | Fadal | 5 | 05-16-2008 09:10 AM |
| VF-3 & Pallet Changer | big_mak | Haas Mills | 14 | 10-12-2007 02:00 PM |
