Can someone tell me what the purpose of this resistor is? I fully understand what its for on the spindle (brake) but why is there one on this board? It appears as if its controlled via clamping the 160 volt buss through the resistor via an IGBT. Anyways I think the IGBT is bad because the resistor is always applying power to the resistor no matter what the condition even when the power is turned off. It also blew the 2 white wire wound resistors that are 300 ohm. Haas wants $500 for another board with exchange. There isn't $100 worth of components on this board so I think I am gonna fix it myself. Just trying to understand why there is this circuit there to begin with. Last edited by DaOne; 02-02-2010 at 07:58 PM. |
| Nobody knows anything about this board? I have ordered all the parts for it. I will post the results. After reading though the forums I see that quite a few others have experienced the same problem I have now. If this fixes the issue it will hopefully save others a chunk of $. I am almost sure that I know what caused the failure. I just wish I knew why this circuit is in place to begin with. |
| Thanks for posting up the details. I don't know if anybody has tried to repair one of those boards but, I'm sure the regen resistor does the same thing that it does for the spindle: provide electric braking for the axis it's attached to. As you figured out, if that IGBT shorts, it will overheat the resistor.
__________________ Greg |
| I'm no electronics expert but, I think that's exactly what the IGBT is there for. My guess is that the IGBT switches the motor from the DC buss coming in, over to the regen resistor during slow down (the DC motor is back-driven by the moving mass, becoming a generator). I haven't actually worked on one of these but, that would be my guess. The connection and symptoms you're describing sound similar to an IGBT failure in a vector drive; the regen resistor gets to glowing on top of the cabinet whenever the servos are engaged and the vector drive throws an error. That sounds like the same symptoms you're describing but, with an axis amplifier.
| DC Brushed servo rebuildable? | tjs88yj | General Metal Working Machines | 4 | 05-25-2009 06:56 AM |
| servo and spindle drive regen load resistors | daleman | Haas Mills | 27 | 12-04-2007 11:28 AM |
| Ac Servo Vs Brushed Dc Mtr? | GARG69 | General Electronics Discussion | 1 | 06-05-2007 01:33 PM |
| Haas VF-3 servo distribution power supply failure | Drkk | Haas Mills | 0 | 12-03-2006 09:48 PM |
| Brushed DC Servo Motors | drk | Servo Motors and Drives | 1 | 06-04-2005 08:51 AM |
