Old 01-25-2010, 10:15 PM
panaceabea is on a distinguished road
engraving around a cylinder G107
Could someone get me up to speed on engraving text around a cylinder with G107 and G47?
I would like to use "g47 P1 (###) " to engrave sequential serial numbers around 2" diameter tubes
I am familiar with engraving and am in hopes it can be wrapped
Old 01-25-2010, 10:22 PM
Have you read your manual? Any linear axis can be cylindrically mapped to any rotary axis (one at a time).
Old 01-25-2010, 10:39 PM
I have and was hoping for a simple example , I am just a little fuzzy on how the g107 line should be written
If my current g47 line reads as follows , what would the g107 line before it read ?
G47 P1 X9.5 Y0.0 I90. J.15 R.05 Z-.01 F20. E4. (####)
Tube is 2" diameter , would it simply be G107 A0 X0 R1.
Old 01-26-2010, 11:11 AM
OK got it , the axis you want to swap to the A axis goes on the g107 line , some how that just didnt translate in the example in the manual, very simple now that I have a grasp.
G107 Cylindrical Milling on Oi-TB lowehardware Fanuc 15 08-12-2010 05:27 PM
Newbie- cylinder copperhead4321 Solidworks 1 05-13-2008 10:20 AM
G107 rajeshtikar G-Code Programing 1 10-22-2007 10:14 AM
g107 on the haas ultrapeter General CNC (Mill and Lathe) Control Software (NC) 1 09-06-2007 08:15 AM
compressor piston cylinder compared to an IC engine piston cylinder CNCnUtZ I.C. Engines 1 12-28-2003 07:06 PM
