Old 01-22-2010, 08:23 PM
Cartel, LLC is on a distinguished road
4th axis VF-3
i have a VF-3 that is pre wired for fourth axis output etc... what all is needed to add the 4th axis?
Old 01-22-2010, 09:36 PM
Depends which 4th axis rotary you want; anywhere between $6k and $15k I think.
Old 01-23-2010, 02:11 AM
Delw is on a distinguished road
youll need the 4th axis drive and rotary table
Old 01-23-2010, 09:12 AM
HuFlungDung's Avatar
Moderator
Come on, Geof, it is not just about the money You also need the desire, the passion to want to see a rotary thingamajig turning with extreme positioning precision, all by itself without counting holes in plates
Old 01-23-2010, 09:59 AM
Originally Posted by HuFlungDung View Post
....... the passion to want to see a rotary thingamajig turning with extreme positioning precision, all by itself.....
Yes, and rotating the workpiece right into the spinning tool you neglected to lift high enough.
Old 01-24-2010, 08:16 PM
roundman is on a distinguished road
Smile 4th
Yep and don't forget about that coolant nozzle thingy clearing the 4th instead of hitting. 4th axis is fun stuff yet I am not sure about the passion part.
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
