Old 01-15-2010, 11:42 AM
rickturner646 is on a distinguished road
Haas TM-1 machine size
Can anybody tell me what the external dimensions of a TM-1 mill are?
I'm thinking of putting one into my garage so need to figure out if there is enough clearance.
Cheers,
Rick
Old 01-15-2010, 11:54 AM
behindpropeller is on a distinguished road
http://haasportal.net/Portals/57ad71...;20Views_A.pdf
Still glad we got our TM-2! Wish I had more time to make stuff instead of design.
I highly suggest the full enclosure for the machine!
Tim
Old 01-15-2010, 12:30 PM
TM-1 Size
Ta!
Rick
Old 01-15-2010, 01:38 PM
hst hst is offline
hst is on a distinguished road
Rick:
FWIW, it is possible to get a TM-1 through an opening 72" wide by 86" high. You have to take a few pieces off, but nothing difficult or critical.
Glenn
Old 01-15-2010, 02:34 PM
bigbaz is on a distinguished road
Originally Posted by hst View Post
Rick:
Glenn
I can go one better than that, put a TM-2 through a door opening of 42" wide. the driver of the hiab lorry looked at the machine with the extra wide splash gaurds fitted and looked at the small doorway and thought i was crazy, I wasn`t 100% sure it would go through but i stripped of all the sheet gaurds then pushed the back of machine into doorway then turned it 45 degrees and wound the table into building then squared it up again and job done.
Old 02-25-2010, 12:58 PM
visbert is on a distinguished road
Hey behindpropeller, where did you find that file? I'd like to find something like that for my TM-2.
Albert
Old 02-25-2010, 01:02 PM
Albert
Its hidden in the "dimensions detail" link
http://haasportal.net/Portals/57ad71...ne%20Views.pdf
Old 02-25-2010, 01:07 PM
Ah, there it is. Thanks.
What's your machine size? Karlf DIY-CNC Router Table Machines 18 08-04-2009 09:40 PM
Need Help!- Haas SL-10 not holding size. Mr.Xtreme Haas Lathes 22 05-21-2008 11:12 AM
MACHINE SIZE LYN BYRD Mach Software (ArtSoft software) 6 04-17-2008 12:42 PM
Need Help!- what size 3 phase coverter haas vf-2 mls Haas Mills 1 04-05-2008 08:01 PM
Servo size for this machine XLR84x4 DIY-CNC Router Table Machines 2 06-08-2007 01:11 AM
