Old 12-09-2009, 10:40 AM
hrhoward is on a distinguished road
Alarm 122 and 176 at Power up
Hello,
I have a problem with a HAAS VF-0E. We just got this machine in last week (used).
I have run 240 vac to the main cb. and tapped the transformer accordingly. When power on the machine I will get the following alarms:
Alarm 122 Overheating of regen
Alarm 176 Over Heat Shutdown
Then it will shutdown in 30 seconds.
Where should I start looking?
Thanks,
Heath
Old 12-09-2009, 02:34 PM
rlabonte18 is on a distinguished road
there is a small transformer up by your main breaker that is dual voltage you may have to change that one also.
Old 12-09-2009, 02:41 PM
rlabonte18,
Thanks for the reply. I know the transformer you are talking about. I have about 241 vac on the primary side and 28 vac on the two red wires on the secondary. Is that within the limits or is it to high?
Old 12-10-2009, 12:43 PM
Have you checked the buss voltage? Go to the Diagnostics screen and page down once or twice; it should be between 320 and 340 DC.
If the voltage is correct it is possible the regen circuit is faulty and the regen resistor is in the circuit all the time. I believe there is a relay that closes when the buss voltage gets above a certain value during braking of the spindle. If this relay sticks closed the DC buss is dumping power into the regen resistor all the time.
Old 12-10-2009, 01:01 PM
Haas__man is on a distinguished road
regen overheat and overheat shutdown.
What is the year of manufacture of your machine?
Old 12-10-2009, 01:15 PM
Geof, I have 340 VDC. What you describe about the regen circuit, could this happen during start-up? I have felt around the resistors on top of the control box and I have never felt any warmth coming off of them.
Haas__man,
It was manufactured in Feb. of 1998.
Old 12-10-2009, 01:55 PM
Overheat shutdown
Ok, if the regens do not feel warm then I would suggest that you probably just have a loose wire - or maybe there is a problem with parameters.
Loose wire -
Open the electrical cabinet door (turn off machine)
Look at bottom left of cabinet
this is I/O pcb
Look down the laft hand side and you should see lots of small brown plugs
most of these should be labelled up
One of these should be labelled up 'regen' or ' regen overheat' something like that
Just basically check they are all plugged in
Double check by unplugging each one and plugging back in to make sure it's not just a loose connection.
Then at right hand side of cabinet should be a white box with vector drive printed on it. (This is still live up to half an hour after machine is turned off so beware)
You are again looking for a small brown plugnear the bottom left of the unit. Again check to see if it is plugged in, and unplug and plug it back in.
Parameters.
It could just be a parameter that is set wrong. Let me know what software version you have ( probably around 9.40n).
Then look at parameters.
You are looking for one that reads 'Overtemp nc' it will be either a '1' or a '0'. You will find it in either paramter 57 or parameter 209.
Let me know what this value is.
Old 12-10-2009, 03:12 PM
Haas__man,
I checked the plugs on the I/O board, unplugged and plugged them back.
I also did the same on the Vector drive.
I have softward version 9.58 n.
I found an "Over T is NC 1" in the parameter list.
Also, the contacts K1 and K4 are energized.
Old 12-10-2009, 03:52 PM
Ok,
That parameter is set correctly.
If you go in to diagnostics (parameter button twice)
What do you see?
you should see two columns of descriptions and number '1's and '0's.
Are they all '1's or all '0's or just random? One of them should probably be flashing from a 1 to a zero constantly (red beacon)
Turn machine off and open electrical cabinet.
On the i/o pcb again (bottom left of cabinet)
you will see four small ribbon cables
one near top left
one near top right,
one near bottom left
one near bottom right
I think there is also another one that is a larger ribbon cable too.
Same as before, unplug each one and plug back in
you will see a small plastic lever on each side of the socket these are used to remove the plug only, to plug cable back in just push until the levers click back in.
These cables go up to the MOCON pcb which is located at top left of cabinet.
Remove the cover at top left of cabinet
you will then be able to see the mocon pcb
Top left of the mocon is the large ribbon cable, top right are the four ribbon cables again.
unplug these in turn and plug back in.
Then refit cover (and ground cables)
Turn on machine to see if fault has gone.
Old 12-11-2009, 07:53 AM
Haas__man,
Thanks, I will give that a try this morning after my coffee infusion takes effect.
  #11   Ban this user!
Old 12-14-2009, 10:17 AM
JoBwan's Avatar
JoBwan is on a distinguished road
I'm getting excited to see what the fix actuall is!!
Just a good ol' boy, never meanin' no harm.
Joe
  #12   Ban this user!
Old 12-14-2009, 03:55 PM
I will check out what Haas__man suggested on Wednesday. Have a couple things I have to work on before I get back to the Haas.
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Pmc Alarm 101 Power Off During Atc danielwestern Fanuc 6 02-25-2009 09:02 AM
401 Alarm when power-on on OM Namnp2007 Fanuc 0 08-04-2008 08:36 PM
Need Help!- Alarm 110 on Power Mate Model D/H AZDEN Fanuc 8 05-05-2008 08:09 AM
Okuma LC20 108 Alarm-A / EC Power Off anyone??? davtbarber Okuma 2 11-25-2007 09:33 PM
