Results 1 to 5 of 5
Thread: HAAS HS1
    Nov 2009
    australia
    HAAS HS1
    First of all hi to every body ,
    I just brought a 1995 HS1.
    4 AXIS,
    I have had no training yet ,
    The machine is levelled By Haas.
    The tool hollder is BT40,
    there is a threaded insert on the top of the BT tool
    there are different versions of this screw on tip,
    I have no tooling yet .
    There is a tombstone mounted and i fitted a 10 INCH CHUCK,
    soon i will mount a vice on the opposite side of the tombstone,
    I have read the manual but i know i need training to get some,
    thing to happen,
    Cheers,
    john,
    Jan 2007
    those are nice machines, if we ran production more we would have boughten one.
    the insert your talking about is a pull stud that screws into the top of the tool holder, Make sure you get the exact type listed on the side of the machine. and only that type and style.
    haas can supply them as well as most tool places on and offline.
    dont play with it till you get training.
    Nov 2009
    australia
    HS1
    Thanks,
    the 4 sided tombstone is a compact package,
    i have a lot of turned products that need finishing off
    It looks like i will have to take my time on this ,
    Nov 2009
    australia
    HS1 parts
    The bottom apron which slides and has 4 segments,
    that slide has rubbers to stop chips going inside ,
    i removed the section and there is 3 levels of rubber badly
    perished,
    Any body know where i can get the right section of rubber to
    Fit properly?
    thanks,
    Nov 2009
    australia
    under the main spindle is a sliding apron ,
    the rubbers are badly perished,
    Any clues where i can get rubber to replace and cost?
    1. HAAS SL20 and HAAS VF2 ProE Posts?
      By CNC_student in forum Post Processor Files
      Last Post: 11-29-2012, 05:48 AM
    2. haas SL-20 to Haas bar 300 alignment plate needed
      By J-Mccoin 2009 in forum Haas Lathes
      Last Post: 12-02-2009, 10:13 PM
    3. RFQ haas SL-20 to Haas bar 300 alignment plate needed
      By J-Mccoin 2009 in forum Employment Opportunity
      Last Post: 10-28-2009, 03:17 PM
    4. Haas Super Mini-Mill and Haas Trunnion Table
      By Gabe Newell in forum Haas Mills
      Last Post: 06-07-2009, 02:23 PM
    5. HAAS Service HAAS Repair NY NJ CT PA
      By serviceman in forum Product and Manufacturer Announcements
      Last Post: 01-04-2008, 04:27 PM
