Old 11-25-2009, 12:41 PM
hst hst is offline
hst is on a distinguished road
TM-1 Table Clearance
Gentlemens:
Could one of you TM-1 owners tell the the real world dimension from the back of the table to the column of the machine, with the table moved as close to the column as possible? I wish to know how far a vise or other fixturing can overhang the back of the table.
Thank you for your help. There seems to be a bit of confusion (at least for me <g>) on this regarding the Haas dimensional drawings.
Glenn
Old 11-25-2009, 07:25 PM
CJH CJH is offline
CJH is on a distinguished road
Well I would guess that you are looking at buying a TM-1. They are great machines for for someone on a budget. I'm not in the shop right now, so doing this from memory. If i remember correctly the distance between the table and the machine column casting is a little over 3.125". This can be amazingly deceptive when your setting up the machine with fixtures and such. the reason I say so is that the sheet metal that covers the Z Ballscrew substracts from this measurement. I never let the fixtures on our TM-1 overhang the table more than 2". I had a Kurt vise mounted on the table with the standard work stop that they sell for the vise that mounts on the back, located on the center T-slot one day and was using short tooling in the spindle and had a crash with the sheet metal on the Z.
CJH
Old 11-26-2009, 11:54 AM
John Crawford is on a distinguished road
I just measured my TM-1 and it's a bit less than 1.6 inches from the back of the table to the front of the Z ballscrew cover. It's tough to get a precise measurement because the cover isn't perfectly flat, but I'd say that 1.58 inches is a pretty safe number.
Old 11-27-2009, 12:19 AM
hst hst is offline
Gentlemen:
My thanks to you both for your help.
I am beyond the thinking about stage, as I have a TM1 on order. I am now collecting some tooling whist waiting for it to manifest itself here. Based on the information you have provided I have decided to go with the Kurt 688, which appears to be a perfect fit.
Best regards,
Glenn
Old 11-27-2009, 07:27 AM
SORCHEROR is on a distinguished road
im not sure about the dimension,but i will say this,i put a vise on mine in the center T slot
over hanging the table and it cleared,but when i bolted a stop on the outer backside
the cap screw got caught and bent my z axis guard,so watch out for that one as i over looked it and had to straighten it,ive had my TM-1 for 4 1/2 years now,great little machine
and no problems,good luck
Clearance, Retract and feedplane Stebedeff Mastercam 3 03-10-2009 10:01 PM
Clearance for square ballnuts on X2? sansbury Benchtop Machines 5 07-30-2008 10:22 PM
BobCad/Cam V21 Clearance Sale Syil_Australia Product Announcements & Manufacturer News 8 07-08-2007 03:17 PM
Mastercam X - z clearance. jderou Mastercam 4 10-28-2005 12:21 PM
Too much spindle clearance. ShayArnett General Metal Working Machines 2 01-09-2005 10:23 AM
