Old 11-18-2009, 06:07 PM
kbspeed is on a distinguished road
Adjusting for cutter wear?
I am wondering if there is a way to write code to decrease the cutter diameter (radius) after each ccyle of the machine. We are grinding glass parts and are trying to figure out how to program the machine to take into effect the wear on the grinding wheel and buffing wheel. Currently manually (typing in, really sucks) decreasing the size of the wheel.
Old 11-18-2009, 06:10 PM
JohnUrz is on a distinguished road
Try Using the ware offset
Old 11-18-2009, 07:18 PM
Use G10 L12 G91 P(Tool Number) R(Change in diameter) in a looped subroutine to incrementally change the tool dia.
Old 11-19-2009, 05:56 AM
I will try this but will it keep reducing the diameter after each cycle of the mill. Does it keep track even after restarting the cycle?
Thanks for the help.
Old 11-19-2009, 08:28 AM
The G10 command does not "keep track" of anything; all it would do is reduce the value in the tool diameter table by the change in diameter you put in the command. You have to enter the starting diameter and you have to estimate how much wear is occuring on each cycle and enter that into the change in diameter.
You are not going to avoid doing some manual entry because it is very unlikely the value you put in for the change in diameter will be exactly correct. This means that gradually the diameter in the tool table will become either smaller or larger than the actual diameter of the wheel as it wears so you will have to periodically correct the tool table entry.
Old 11-19-2009, 11:01 AM
Matt@RFR is on a distinguished road
If you have enough parts to make to justify the cost, you could add the Renishaw probing package. This would allow you to probe the diameter of the wheel and update the tool offset automatically.
Adjusting ACC/DEC on a A2100 Rob_N Cincinnati CNC 3 09-24-2009 10:21 AM
Bit wear? HakBot Benchtop Machines 6 12-02-2007 09:45 AM
Adjusting PlungeRate sunmix Mach Software (ArtSoft software) 5 11-14-2005 06:44 AM
Adjusting backlash on VF-OE eddie Haas Mills 7 12-22-2004 02:20 AM
My neck needs adjusting turmite Rhino 3D 27 10-29-2004 06:59 AM
