Old 11-17-2009, 12:02 PM
WJ MARK is on a distinguished road
ALARM 166
I have a 99 Haas vF-EXT getting an alarm 166 y zero Ret margin too small. Happens when I do a power up re-start. My fixture offsets are in Y are off almost .5" It says in the manual the limit switch moved or are mis-adjusted.
My questions is where is the Y limit switch?? is it on the front or back side of the way covers??? Trying to figure out where is it before I start pulling parts off everywhere! also , anyone know how much a new one costs???
Thanks, Mark
Old 11-17-2009, 05:42 PM
Nobody???????
Old 11-17-2009, 06:03 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
The Y Axis limit switch is located under the back cover...A 99 model I believe will have a micro switch instead of a hall sensor..might just be a sticky switch or a chip or a broken wire..or it could be an encoder going south...
There is a procedure to set the Zero return margin..varies a bit from year to year..But It is normally only done when replacing a servo or encoder...
Old 07-16-2010, 10:11 AM
Stupidav is on a distinguished road
I know this is an older post, but as WMS says "normally only done when replacing a servo or encoder..." If you had replaced either of them, just rotate the motor 90deg with the mounting bolts and you should be fine. In a few cases I have seen you might have to try going up to 180deg, but generally the 90deg rotation will take care of the problem.
Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Problem- Alarm 350, not in my alarm list, any ideas? ralph@nes Mazak, Mitsubishi, Mazatrol 4 09-27-2008 01:14 PM
