Can a haas indexer be used as a full fourth? Are the units that use an indexer control able to be plugged in to a machine with a fourth axis card and be used as a full fourth axis? Thanks. Last edited by WGJ; 11-17-2009 at 07:56 AM. |
| Yes all the Haas rotaries can work as a full fourth axis on Haas machines with a fourth axis fitted. I have no idea if you could adapt a Haas rotary to the fourth axis wiring on a different make of machine but I suspect it is not possible.
| On another thread someone was asking about adding a 4th axis to a mini mill and was told that the option has to be activated at an additional charge even though he had already bought a driver board and rotary table. My question is about the VF models. If buying a used VF that has the factory pre-wire and motor driver for the 4th axis is it still necessary to pay Haas to activate it? Or can you just plug in the rotary and run it with a couple of parameter changes? Thanks, Ralph |
I thought you just tell it you have the fourth turned on? I remember seeing the parameter. Tim |
#10
| The proper way to enable the indexer is to turn on machine and hit E-stop. With all servos disabled change setting 30 to your indexer WRITE/ENTER and then shut off power. Plug up indexer power and air, then turn back on power and release E-stop, reset etc. The indexer should then function as the A axis. If your machine has the pin plugs for the indexer (A axis) then it should be able to use the 4th axis. If a 4th axis was not installed there would be no connections on the control panel side for the indexer to plug into. Just saw a machine come in without the option and watched them install the option, the plugs were part of the installation. |
#12
| On the HAAS VF5 and VF6 when you go to settings and setting 30 in particular it should be off. Arrow right through a list of indexers. 210, 310, 310B etc. If you choose the wrong one an alarm will more than likely be generated when you attempt to use it. Make sure you know which one you have. Ours has 310 stamped on it but it is really 310B (brushless). 310 generates an alarm. When you find yours hit WRITE/ENTER. The indexer is enabled. When you enable it the servos should be stopped and it is a good idea to have the power off when the indexer is plugged in also. |
| Haas Indexer | binzer | Haas Mills | 13 | 12-15-2009 08:10 PM |
| Haas VF with HRT210 indexer, M21 | Talisman | Haas Mills | 4 | 10-22-2009 10:02 PM |
| Low cost HAAS-Indexer | mebe90 | General Electronics Discussion | 0 | 04-04-2009 06:52 AM |
| Haas VF1 & 5C Indexer | lovell110 | Haas Mills | 3 | 12-07-2007 11:39 PM |
| Haas S5C Indexer motor | Andrew M. | Haas Mills | 11 | 09-02-2006 09:57 AM |
