Old 11-14-2009, 11:57 AM
Mike T. is on a distinguished road
Pressure switch
I have been getting some good advice on an issue with a mini-mill low pressure alarm. The problem is with the pressure sensor under the front cover-just as I was told. I bypassed the sensor-against my better judgement,but need to finish a job. The machine is running fine, but I need a new sensor and this part does not have any part number or anything to identify it by. Does anyone know what PSI I am looking for. The brand name is Hobbs. Thanks again for all of your help.
Old 11-14-2009, 12:47 PM
Al_The_Man's Avatar
It looks like Hobbs have been taken over by Honeywell.
http://content.honeywell.com/sensing.../catswitch.asp
I don't know if there is enough info there to identify it?
What is the function the P.S. is on? Lube oil?
Old 11-14-2009, 01:30 PM
This switch is mounted above the spindle- I believe it is relatively high pressure. I just want to be sure that it is not too much or too little pressure.
Old 11-14-2009, 02:02 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Mike,
The manual says it alarms at below 80PSI..so I'd guess an 80psi switch..
Haas will have one if in doubt..usually reasonably priced..
Old 11-14-2009, 02:29 PM
Al_The_Man's Avatar
If the 5000 series, looks like it runs around $35.00.
http://content.honeywell.com/sensing...scorp/P3_6.pdf
The adjustable type, usually have a plug in the top and this exposes an allen set screw to adjust.
Old 11-15-2009, 09:17 AM
Al_The_Man's Avatar
Are you sure it is the switch and not the pressure or adjustment?
The switch itself could be OK, if it has the adjustment set screw, back it off one complete turn, if the switch operates OK under pressure, then it most likely is OK, turn it back in one turn and check the pressure source.
Old 11-15-2009, 10:19 PM
judleroy's Avatar
judleroy is on a distinguished road
You can buy some pressure switches at lowes. I'm not sure what your using it for but you can probably find a comparable psi switch there. I used one to attach inline to the coolant pump on a router. It would automaticly turn on a sump pump to keep the tank from overflowing on the floor. Judleroy
Need Help!- pressure switch bibi Laser Engraving & Cutting Machines 8 08-07-2008 02:01 PM
New Transmission Air Pressure Switch Rcky123 Haas Mills 0 05-05-2007 01:11 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
