Old 11-11-2009, 04:20 PM
ltru is on a distinguished road
10 month old VF2 has weird spindle noises...
We've purchased a brand new VF-2 that was installed beginning of 09 with under 200 machine hours on it.
Recently I've notice a weird spindle noise during warmup. The noise sounds like something between bearings rubbing improperly and higher pitched gurgling in the head and is most obvious at around 1500 - 2000 RPM.
The noise is still there at 100 RPM but is very subtle and is proportional to the RPM speed of the spindle.
A factory outlet tech came out to check out the machine but havn't fixed it yet because we're waiting on HAAS for a response on the spindle analyzer results, which has been a few days now.
Anybody have any idea on what may be causing the noise?
Edit: Forgot to add, the encoder at the top of the spindle "wobbles" with the spindle running and the noise SEEMS to be coming from there, however the tech said he replaced it with a new one but it didn't fix the problem, so the original one is back in. Is the encoder suppose to wobble even though it is secured?
Old 11-11-2009, 04:43 PM
mactec54 is on a distinguished road
No the encoder should not wobble, If they did a vibration check they can tell you right away if the spindle has a problem
Mactec54
Old 11-12-2009, 04:30 PM
Cory is on a distinguished road
My machine has this same problem. You don't even want to hear my horror story with how many gearboxes/tests we went through with it.
Long story short, the factory claims it's because they switched to a cageless bearing in the gearbox. I don't think bearings shouldn't sound like they have sand in them, regardless of their construction, but my HFO doubled the warranty on the new gearbox and I don't see any issues with surface finish/holding tolerance, so I'm not too worried about it.
Old 11-13-2009, 09:17 PM
charger19690 is on a distinguished road
Make very sure you have as much of the report in writing. I know from our experiences, ( a shop with about 24 Haas), if it's a couple months over warranty, you will be out of luck.
At least if you have the initial report before your warranty ends, you might have a chance to get something repaired.
Mike in MN
http://www.cncbasics.com
http://www.cncbasicsforum.com
http://www.mastercamforum.com
http://www.mastercamblog.com
www.cncbasics.com www.mastercamforum.com
Problem- Strange signal noises from pic16f84a CyberArtem PIC Programing / Design 5 02-10-2009 09:36 PM
Need Help!- crashed the machine, now spindle makes weird noise!!!! lm6769 CNC Machining Centers 7 09-01-2008 12:23 PM
The Month from Hell! SpeedsCustom Benchtop Machines 24 06-02-2008 10:27 AM
L298/L297 strange stepper motor noises cnc kiwi Stepper Motors and Drives 7 12-26-2007 10:18 AM
Whine / squeal noises when machine idle bkraz Bridgeport and Hardinge Mills 5 02-09-2006 05:29 AM
