Old 11-10-2009, 06:49 PM
Mike T. is on a distinguished road
Haas Mini Mill Pneumatics
HELP!! I have a Haas mini mill. One of the guys in the shop took apart the Air regulators in the back of the machine- the incoming, the low pressure regulator,and the automatic lube manifold and valve. I was assured that he knew exactly how to put it back together, well, guess what!!! any pictures,makeshift diagrams or info would be GREATLY APPRECIATED!
THANKS!
Old 11-10-2009, 07:58 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
How about this..hope it helps..sorry a bit dark back there..
ID:	93129   Click image for larger version
ID:	93130   Click image for larger version
ID:	93131   Click image for larger version
Old 11-10-2009, 10:29 PM
Thanks, I hope that gets me started!
Old 11-11-2009, 06:10 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Mofified Pictures
I lightened up the pictures a little bit. It may help on seeing more of the details.
ID:	93181   Click image for larger version
ID:	93182   Click image for larger version
ID:	93183   Click image for larger version
2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/
Old 11-11-2009, 09:27 AM
These pictures have been extremely helpful THANKS!!!
I still am looking for any idea where the low pressure regulator is hooked in. It is behind the panel where the regulator is mounted, but any type of description would really help. Thanks again!!
Old 11-11-2009, 11:15 AM
wms's Avatar
wms wms is offline
Moderator
Couple More shots
ID:	93204   Click image for larger version
ID:	93205   Click image for larger version
Old 11-11-2009, 04:55 PM
Question
Thanks, Got it back together,but still getting the low pressure alarm that I was getting originally. Changed the regulator,and have enough air pressure, but still no luck. does anybody know if there is anything that could be blocked elswhere on this machine???? Thanks again for the help!!
Tags
haas, haas mini mill
Haas Super Mini-Mill and Haas Trunnion Table Gabe Newell Haas Mills 6 06-07-2009 01:23 PM
Problem- haas mini mill johnmckeown Haas Mills 11 02-19-2009 10:26 AM
Haas mini mill pyroracing85 Haas Mills 11 05-11-2008 07:33 PM
HAAS Super Mini Mill Ford25 Haas Mills 13 09-07-2007 08:01 AM
Haas Mini Mill Maintenance slatern44 Haas Mills 11 08-28-2007 06:50 PM
