I'm running a Haas-VF machine we picked up used a few months ago. It's been running great. We are doing some aluminum machining, running a .005 finish pass on this project, and the Z Axis crashed. We got a 105 Alarm, and the head actually dropped down and buried itself in the aluminum block down to the collet. I wasn't watching the machine when it happened, so I don't know if it alarmed out before or after it let loose and dropped into my workpiece. I did check my G-codes, and I don't see anything in there that would cause it to plunge into the material like that. I reset it and everything appears to be fine, but what would cause that, or what should I look at so I don't trash another piece of material? Thanks in advance for your input. |
| Had the same program built a good part before the crash? Were there any programs loaded or verified between good parts made? Depending on the size of the end mill, it would probably have to be "driven" into the part to get it up to the collet chuck, but you said the end mill was buried in the part, so I think it wasn't small enough to just shatter, (so not just a collapse). It is an error in the code, or "O.E." Feel free to correct me anyone. My 2 cents, Robert
__________________ The beaten path, is exclusively for beaten men. |
You should probably have the drawbar tested with a pull gage, to see if the drawbar pulling force is within specs. You may (probably) have broken some belleville washers in the drawbar assembly. This could result in bad surface finishes and tools not being tight enough in the spindle. Just my $.02 worth. Good luck,
__________________ Just a good ol' boy, never meanin' no harm. Joe |
| I need a crash course!!! | dpotts | Diemaking and Diecutting | 4 | 09-03-2009 07:09 AM |
| Need Help!- Crash | shaju | Daewoo/Doosan | 10 | 11-05-2008 11:22 AM |
| z axis crash need help | timmydabull | Haas Mills | 7 | 01-18-2008 08:33 PM |
| Serious Crash | bbrreid | General CNC (Mill and Lathe) Control Software (NC) | 4 | 07-30-2007 05:16 PM |
| I need a crash course!!!! | dpotts | Moldmaking | 0 | 03-31-2007 11:48 AM |
