Old 10-26-2009, 06:53 PM
rickkiefe is on a distinguished road
Troublrs drilling on center in Haas SL20
Can someone help with this. We are trying to center drill, drill and tap on center in our lathe. We are off center by .012 for some reason. Can someone explain to me the best method for finding spindle center with toolholder for drilling. The jaws are bored, we are using a outside face holder, with drill chuck insert. Seems perhaps center is not picked up perfect, but not sure best way to pick up.
Thanks,
Rick
Old 10-27-2009, 12:47 PM
The CNC Noob is on a distinguished road
Im a little rusty on lathes, but will give it shot. Im used to running a hl2 so it may not be the same. I usually just press f1 which is distance to center when you are touching off the tool you are using. It will automatically input the distance to center in x. Its the same as touching off your turning tools except you dont input a diameter and just press f1 to get the distance. That should give you center unless something has changed on the machine.
Old 10-27-2009, 01:32 PM
ChuckH is on a distinguished road
Hope this help's, I just read the FAQ's at the Aloris web sight and it gave a discription on how to do what your asking.
Chuck
Old 10-27-2009, 02:15 PM
HuFlungDung's Avatar
Moderator
Perhaps the tool is above or below center by .006". This might require shimming the turret or making a slightly offset-eccentric toolholder somehow, as a patchup.
Haas SL20 rickkiefe Haas Mills 2 10-19-2009 11:52 AM
MQL in Haas SL20 ? Sachn Haas Lathes 1 09-09-2009 08:22 AM
haas sl20 ashro Haas Lathes 2 07-24-2009 07:52 AM
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
