Old 10-22-2009, 04:06 PM
espinja is on a distinguished road
Haas vs Inconel
Our company is looking to buy a Haas VF2 VMC. This is for a new process to cut turbine engine inconel Blades, there aren't heat treated yet.
My question is if anybody has experience cutting inconel with haas vf2 machine.
Need to know if the machine is going to have any trouble cutting thru this hard material.
......Thanks
Old 10-22-2009, 09:42 PM
mls mls is offline
mls is on a distinguished road
We have done this on a 1998 vf4 it works but we only have 6 pcs at a time and it is not a big area we are machining.
I think if you are not trying to use big tools it will work fine if you are going to try to hog metal with a 1 inch mill it is not the machine for you.
Good Luck Mike
Old 10-23-2009, 01:39 PM
SlowRiderr is on a distinguished road
......Thanks
A new or used machine? What spindle are you getting?
Old 10-23-2009, 08:19 PM
crabbass is on a distinguished road
......Thanks
I cut a lot of high temperature alloys on our VF3, however I do not do any quantities that anyone would call production. Get the gearbox option, and good luck, this is a very competitive industry, If the design isn't new, someone will beat you out with a forged product.
And for your information, Inconel isn't necessarily hard, it is abrasion resistant, the hardness is usually measured in the brinell scale, and It doesn't go through a heat treatment for hardness, rather it is solution annealed to normalize the structure.
Need Help!- Fadal vs Inconel espinja Fadal 0 10-22-2009 03:25 PM
Need A Quote- inconel 710 jaimeoro Machinist Feedback 7 03-24-2009 01:25 AM
Inconel 718 Question Mr.Xtreme Haas Mills 9 08-05-2008 03:29 PM
Machining Inconel bigandy Composites, Exotic Metals etc 11 03-20-2008 05:11 PM
inconel positiverake1 General Metalwork Discussion 0 10-15-2007 11:27 PM
