Old 10-22-2009, 02:10 AM
99bluemoon is on a distinguished road
VF3 Door Locking Procedure
We have three VF3 year 2000 machines but only one of them forbids the operator from opening the doors whilst in motion or when the power is switched off.
The other two machines allow you to open them but automatically generate an alarm and switches the spindle off etc.
Is this normal or are the switches faulty? or perhaps a parameter can be set.
They are used machines and have been pretty good. Not had a problem with them until a Health & Safety guy pointed it out today.
The interesting thing is that he failed to pick up the fact that the sliding windows on either side of the machine can be slid up at any time!
Any help would be much appreciated.
Old 10-22-2009, 08:00 AM
Mic6's Avatar
Mic6 is on a distinguished road
I've never heard of a Haas with locking doors, but the Setting 51 controls the Door Hold override which stops the spindle when you open the doors. What are you trying to achieve? HTH
Old 10-22-2009, 11:43 AM
Hi
Thanks for the reply. Personally I am not trying to achieve anything because to I have no concerns whatsoever in the operating procedures of the machines. However, this outside guy asked the question as to why can you physically open the doors when the machine is in a moving mode, even if doing so turns everything off.
One of the VF3's WILL DEFINATELY FORBID the operator from opening the doors during operation.
The only clue is that all machines are UK sourced. Two of them came from a machine merchant with all the operator settings set at default and all old pgms removed etc. The machine that locks the doors came direct from another shop with all the existing pgms in, tool lenths and aluminium chippings! It seems the shop suddenly closed down. This is a cracking machine. My guess is that it is a simple setting.
This matter only came about when I was leaving the shop following a night shift. I will investigate further when I go in tonight.
Thanks DAVE
Old 10-22-2009, 03:40 PM
Haas_Apps is on a distinguished road
You should discuss this with your local dealer. Most of Europe requires interlocks that are not required in the USA.
Haas Automation UK
Bradgate House
No 13 Unthank Road
Norwich, Norfolk
NR2 2PA, England
UK
TEL: +44 (0)1603 760539
FAX: +44 (0)1603 760542
cnc@haas.co.uk
Old 10-26-2011, 09:04 AM
a_staschak is on a distinguished road
Need help! Our shop just bought a new vf-3 Haas machine there is no setting 51 to override door lock once machine is in operation doors lock dont see any parameters either for door lock over ride.
Old 10-26-2011, 09:21 AM
That is correct. If you go through the threads in this forum you will find this topic has be covered again and again over the past year.
Procedure for BMU 6TA SGARCIAM Fanuc 1 10-25-2008 12:38 PM
BCC locking up during DNC. Jim Estes BobCad-Cam 5 02-07-2007 10:03 AM
Help on procedure for machining this part turboboy General Metalwork Discussion 17 12-18-2006 06:50 AM
Question on a procedure gv71 OneCNC 3 06-13-2006 07:51 PM
